Barn: Stub-out planning before the slab goes in...
   / Barn: Stub-out planning before the slab goes in... #1
Reload5
Texas
LS XR4140HC
Looking for ideas on stub-out(s) for the barn for future services such as power, water, network cabling, etc.
Anybody happen to have some good pics of what you had done before the concrete went in?
   / Barn: Stub-out planning before the slab goes in... #2
Power
3 phase 600volt
Com
Air
Heating (The biggest pipe)
Old paint cans were used to make openings in the foundation wall below grade.
Oh, I forgot water, drains, and a floor drain.
Then some extra pipe for control cabling for the (possible wood boiler) heating system
   / Barn: Stub-out planning before the slab goes in... #3
And, how some of the services looked before the floor was poured.
   / Barn: Stub-out planning before the slab goes in... #4
No pics,,, because there is too much "stuff" in the shed.
I ran the gray PVC (2" IIRC) all under the place.
I put it in for the input power to the electrical panel.
I have PVC for future installations of propane, water, cable TV(LOL!! :laughing:)
I even put 3/4" PVC in for a possible land line wire,,, who knows,,
my shop is metal (entirely) so cell service is horrible.
Then,,, I ran the same size PVC from where the electrical panel is to 4 other areas of the shed.
My ceiling is mostly 22 feet high, I figured wire under the slab would be neater than overhead.
With short runs of conduit, I have very clean looking electrical installations.
My air compressor is near the electrical panel, I may use one of the PVC's for a remote air outlet.
I also "roughed in" for a full bathroom in one corner,,,
PVC is so cheap,,, put EVERYTHING in that you can dream of,,,
it will look great later.
Oh, yea,, the only thing I didn't do was to install some sort of "man hole" where the PVCs' exit the building.
Each time I up date something,, I gotta hand dig with a shovel instead of a backhoe.
I can not risk damaging the esisting installations, and I can not leave an open hole,,, :confused2:
   / Barn: Stub-out planning before the slab goes in... #5
Plan carefully, then add a couple of empty caped off conduits for unexpected cables, security systems, etc.
Keep in mind that quite often the pipes and conduit are not staked well enough and are bumped or moved in the concrete pouring process.
Cap everything, sometimes objects are dropped into the pipes or conduit during the project.
Have all water pressure lines in a protective sleeve of some kind.
Keep in mind clean outs that can run both directions due to the possibility of having to run roto rooter type equipment in the drains or vents. So sweep "T"s or elbows, the more genteelly the better.
Well under 100 ft and even better keep less than 50 ft between clean outs.
Sorry no pics :)
Thanks folks for the responses. Looks like I need to spend a bit more time thinking through all this...
   / Barn: Stub-out planning before the slab goes in... #7
Yes, do it till it just about drives you crazy, like it did me.
2005 CHEVROLET (A55788)
2005 CHEVROLET...
New Idea 14A Manure Spreader (A50775)
New Idea 14A...
UNUSED JCT 84" HYD ROCK GRAPPLE BUCKET (A54757)
UNUSED JCT 84" HYD...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
12' CONTAINER (A54757)
