Barn Doors
/ Barn Doors #1
RanchMan
Platinum Member
Texas
Mahindra 4110
I plan on putting up a pole barn as has been discussed on the various threads here. The structure itself isn't the issue - what bothers me a bit is the doors.
I've thought about putting in a regular garage-type door, but was also thinking about regular "swing open" double-doors or maybe one that runs in a track like an airplane hangar.
Since I'm doing all the design/build work myself, I was thinking someone here might have some ideas on diagrams/designs or where to get the appropriate parts for such doors.
Any ideas?
/ Barn Doors #2
I went with the sliding door 10ft wide. The swingout doors require to much room to open and tend to dip with age. The rollup doors are noisey and in my opinion do not look good. The regular garage doors were an option but would have required me to have framed for the runners over the door.
The slide door kits are available at Lowes/homedepot/tsc/etc. I got mine from the company I bought the rest materials from.
See attachment.
/ Barn Doors #3
I have swing out doors on our garage and sliding doors on our barn. I much prefer the sliding doors. While it might not be a problem in much of Texas, I have to shovel the snow 3 feet in front of my garage just so I can open the doors. Then, once they are open, the wind invariably catches them and slams them shut. If you have the room for a slider, that would be the way I'd go.
/ Barn Doors #4
Ranchman
I think the choice of doors really depends on what you are going to use the barn and doors for. If you are only going to occaisionally move some equipment in or out such as your tractor, then one or more sliding doors would be appropriate. if you are going to store a number of pieces of equipment and/or vehicles, then I think overhead garage doors would be more appropriate. I have a 30' x 40' pole barn construction garage attached to our house in which I store four vehicles. In the winter I also store my tractor and ATV in the garage (three vehicles are for summer use only). I have two 8' x 16' overhead garage doors (see attachment) with electric openers. In not too distant future I plan to put a 25' addition on the garage including a 8' x 18' overhead door.
/ Barn Doors #5
As you know RanchMan, I tend to do things the same as everyone else ... not.
I have overhead doors on both garages and have never really liked them in anything I'm going to insolate and heat. And I have sliders on the barn which tend to get frozen in their tracks in the winter and cause my wife no end of grief.
So ... when I built my workshop, I handbuilt bi-fold doors ... and then just to ensure I had no "winter problems" I have them fold inward instead of outward ... so the snow and ice are no problem.
wingnut
/ Barn Doors #6
I would also go with the sliding doors and if in a snow climate mount on the inside. Snow is then not a problem although you lose that portion of the insode wall to hang stuff on. I think for the money it's also the cheapest way to go. If you have a wood building making the door yourself out of vertical 1x 12's with a couple horizontal 1x 12's and a set in a "Z" pattern is easy and strong. The hardware is readily available at any farm store.
/ Barn Doors #7
RanchMan,
My pole barn has a 10 ft. sliding door.
A concern I would have if I were you is that a sliding door prevents a significant space from having windows. My barn is 30x40 and I have attached a photo of it herein.
Buck
/ Barn Doors #8
I built my pole barn so that the center section could garage my motor home. The opening there is 12' x 12'.
I built my own 12' x 6' swinging doors for it. I made a frame of 2x4's braced both vertically and diagonally and sheathed the doors with T1-11 same as the building. The doors are mounted with 3 12" "T" hinges each lag-screwed into the door bracing and the doorframe 6x6 poles. These suckers are HEAVY but the hinges seem to be holding them square and true (3 years now). But then I don't open the doors every day either - just to take the motorhome out for occasional weekend trips.
/ Barn Doors
Thanks all for the info and pictures! I'll let you know what route I'll go when I finialize my plans.
/ Barn Doors #10
Ranch Man,
FWIW, just finished a 30' x 48' pole barn with 10' ceiling and concrete floor. I chose to install a commercial overhead garage door to get a better seal at bottom than a sliding door. Door rests in a 1/2" recess at edge of floor and has a rubber gasket along bottom to help seal. Probably kidding myself to think this may help deter critters.
JT
/ Barn Doors
<font color=blue>Probably kidding myself to think this may help deter critters</font color=blue>
That actually brings up another question - what do you guys use to deter "critter trespassing" in your barns? I've heard about the benefits of mothballs on a couple of other threads ("Snakes", "Bad Stuff"). Is this what you use? Do you have other recommendations?
/ Barn Doors #12
Oh they will either eat the rubber away, literally, and crawl right in or they will dig under it. I constantly battle them. I haven't even had my new barn built a year yet and it's already got rats and praire dogs trying to make a home. It's a constant battle for sure. I use alot of poison and traps.
/ Barn Doors #13
/w3tcompact/icons/smile.gif
But seriously, I am sure your house is pretty tight but mice still get in.
there are certain techniques used by self storage building builders that keep mice out...no dont know what they are, but I dont remember hearing anyone's stored stuff being damaged by critters.
Hey nice pictures at Pbase site. Are you creating a game ranch?
/ Barn Doors #16
RanchMan .... I have a live-and-let-live agreement with the barn cats. I feed them to keep them around ... but that's as far as it goes .... no trying to tame them or make friends or whatnot.
Since they're technically feraL ... they get along just fine ... might make lunch for a coyote ... but unlikely ... they're wild and therefore pretty careful out there.
I put feed out (small amount) morning and night when I feed the horses ... and they're there ... or not ... but usually there.
I lost 7 last year (kittens) when somebody poisoned them (all died within a few hours ... but the original and 2 of her offspring are still here after 3 years.
I can attest to no mice, rats or other unwanted vermin.
Now ... if someone would give me a (surefire) solution for blasted moles, I would be willing the relax my "live-ad-let-live" stance .... I've sustained an unbelieveable amount of lawn damage in the past year.
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A69167)
2020 FREIGHTLINER...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
Evinrude Johnson 3x13.75x13 Aluminum Marine Motor Propeller (A66734)
Evinrude Johnson...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
