Bargain transfer switch instead of double male ended cord farmer fix
   / Bargain transfer switch instead of double male ended cord farmer fix #1
buickanddeere
Super Member
East Coast of Lake Huron
Deere, several
Found a low cost, quick, easy .safe and effective transfer switch for use with portable generators up to 10KW.
No excuses for using double ended male cords into clothes dryer, electric stove or worse yet welder plugs.
No extension cords through doors or windows and stumbling around in the dark transferring from the sump pump, to freezer, to fridge.
No need to attempt a tie into a hard wired furnace or AC unit.
GenerLink.com - About GenerLink - The easy way to connect a home generator
   / Bargain transfer switch instead of double male ended cord farmer fix #3
Not suitable here as my meter is on a pole out at the road.
   / Bargain transfer switch instead of double male ended cord farmer fix #4
Good idea but local electric utility refused to install it.
   / Bargain transfer switch instead of double male ended cord farmer fix #7
I was looking at the generlink earlier today as it is my most viable option. I have four breaker boxes in two buildings and no way to install a break-before-make transfer switch. Not the cheapest for some folks, but best for my particular situation.
   / Bargain transfer switch instead of double male ended cord farmer fix #8
Asked the electrician about adding a generator connector when he came out to do a load center for me. He said the local codes prohibited whole house connectors for non-fixed generators, and you couldn't get a whole house transfer unless the fixed generator was big enough to carry the full house load...
So, as I type, I've got cords running in through the sliding glass door from the generator to freezer, fridge's, etc. while waiting for the power to come back on, thinking evil thoughts of adding a 30amp two leg breaker to the load center in the basement.
Nick
   / Bargain transfer switch instead of double male ended cord farmer fix #9
That's understandable. I can't afford a whole house generator. But am tired of all the extension cords running through the window. The Honda HP2S will handle twelve circuits. It has a microprocessor. It lets you program the priorities so as not to overload the generator. It will sense load and not kick everything at once so as to not overload the generator. It puts things on standby as the load demands. Everything is going to run but only when HP2S says it should so it won't overload the portable generator.
   / Bargain transfer switch instead of double male ended cord farmer fix #10
It is a good idea, but I have 400 amp service and it will not work on that.
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58216)
WHISPEREATT 25...
5TH WHEEL PLATE (A58216)
5TH WHEEL PLATE...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Super Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
EXCAVATOR RIPPER (A58216)
EXCAVATOR RIPPER...
