Bargain Shoppin'
/ Bargain Shoppin' #1
jwstewar
Elite Member
South Central Ohio
Kubota L3301
Bargain Shoppin\'
OK, I'm tired of you all posting about your great deals that you got. A DeWalt planer at half price, attachments on sale at TSC, or a truck 13k off list. /forums/images/graemlins/smirk.gif Well, I finally got one. It felt kinda good being the first guy calling about something and the other people waiting on my decision of whether or not I wanted it.
I found me a cement mixer for $50. As you can see from the picture it isn't pretty, but it is good and solid - and it works. Needs a little bit of TLC to remove some of the cement that has accumulated through the years where it wasn't cleaned properly. Will probably also replace the cord on it, has run that way for years, but I'll probably put something a little more moisture resistant on it as around cement you usually have water. /forums/images/graemlins/grin.gif
Here is the first picture of the dump mechanism.
/ Bargain Shoppin'
Re: Bargain Shoppin\'
Here is a shot of the other side. You can see the motor. You can also see the bent "tongue." I'll figure out something to do about that and rig up a way so that I can move it with the tractor as it is pretty heavy and doesn't like to move real well.
/ Bargain Shoppin'
Looking in side you can see where someone had left some cement dry on the inside, but not terrible. I'll probably work and clean this out at some point, but I wouldn't be afraid to start using tomorrow on a pour.
/ Bargain Shoppin' #4
It isn't dirty. It's experienced.
Just in case the bearing on the drum is bad. Don't get in a panic. Chances are, most likely, odds be, they're the same ones used in your trailer or the front of a vehicle, ie, wheelbearings. /forums/images/graemlins/grin.gif
You did good. And if you want to gas motor da mixer keep in mind you need one with a gear reduction box.
/ Bargain Shoppin' #5
I picked up a worksaver post hole digger last weekend for $65, does that count too?
/ Bargain Shoppin'
Sounds like it to me, but what is it? /forums/images/graemlins/confused.gif Is that one of the augers with a motor that 1 or 2 guys can run?
/ Bargain Shoppin' #7
nope, its the real deal...
/ Bargain Shoppin'
Yes, then in definitely counts. Wish I could've found that bargain too. I was feelin' pretty good about my find, and now I'm bummed out again.... /forums/images/graemlins/frown.gif
/ Bargain Shoppin' #9
no, no, no... to coin a phrase "it's all good!" /forums/images/graemlins/grin.gif
any deal that YOU find is good for YOU!... well, and perhaps your neighbors, and friends, and family...etc... /forums/images/graemlins/shocked.gif
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
2001 International 4000 DT 466E (A60462)
2001 International...
