Bare metal epoxy primer for truck frame
   / Bare metal epoxy primer for truck frame #81
Getting ready to paint a sand blasted steel truck frame.
Need advice on what bare metal epoxy primer to use.
Frame was rusty and needs prep work. Any professional advice for preparation appreciated.
I use cold galvanizing compound spray as a primer. If it keeps docks from rusting, it'll keep auto bits from rusting. Colored enamel paint seems to stick to it just fine.
   / Bare metal epoxy primer for truck frame #82
You'll also find if you separate the frame, it'll have a bow to the left right where the rear wing mount was
I think I am going to clean the existing double frame as much as I can, but otherwise leave as is, but still intrigued with the possibility of an L overlay on the outside…
Almost sounds too easy not to do at this point.
   / Bare metal epoxy primer for truck frame #84
.....but still intrigued with the possibility of an L overlay on the outside…
If your primary concern is more one of esthetics (which I find no fault in :) ) and secondary is strength, what if you took a 120 grit or so flap wheel after you're done blasting to smooth out the rust depressions. Time you cover it with either paint/undercoating or whatever you're going to use it probably won't be that noticeable especially by the time you get some road dirt stuck to it.
   / Bare metal epoxy primer for truck frame #85
The Taco Wagon frame was primed with some type of acid etching undercoating. Then it was finished off with a double coating of Line-X undercoating. The frame was not sprayed - it was dipped in a tank of the Line-X. For that matter - the entire underside of the Taco Wagon is sprayed with 2X layer of Line-X.
FWIW - mud sticks very well to this Line-X undercoating.
I’d say mostly for strength and 40% for appearance and possible resale down the road
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
