Bare metal epoxy primer for truck frame
   / Bare metal epoxy primer for truck frame #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Getting ready to paint a sand blasted steel truck frame.
Need advice on what bare metal epoxy primer to use.
Frame was rusty and needs prep work. Any professional advice for preparation appreciated.
   / Bare metal epoxy primer for truck frame #2
Check with a local auto paint supplier or body shop. Some primers are made to bond even to rusty areas.
Im hearing products like POR-15 cover rust and make it worse, but that could be rumor. I am planning on having all the rust removed with sandblasting, but it wont be like new metal, either.
   / Bare metal epoxy primer for truck frame #5
If you're getting it sandblasted, will the sandblaster prime it? If not, you'll probably get it back with a flash coat of rust on it. That would be ideal for a Phosphoric Acid treatment (Oshpo). That will convert the rust (iron oxide) to iron phosphate which clings very tightly to iron and makes an excellent primer.
The sandblaster offered to prime it and has a paint booth.
I would think right after sandblast, it should be blown off and wiped down?
   / Bare metal epoxy primer for truck frame #7
If it’s sandblasted clean I would have him prime it. It would be important to get any sand off it and no grease. It seems like sand gets in and nooks and crannies so it would take some time. Good primers often say something like “self etching”.
Keep in mind most primers won’t keep water out. It will stop tge surface rust for a short time but it should be painted pretty quickly.
   / Bare metal epoxy primer for truck frame #8
Had my mower deck sandblasted then coated with 2 part epoxy primer per the SB guy epoxy is best over SB metal. You don't need metal etching primer and epoxy is harder. The only caveat is most epoxy primers recommend painting within 48 hours of application, otherwise if longer than a few days, they suggest to sand the primer for adhesion.
   / Bare metal epoxy primer for truck frame #9
Yep - Wouldn't hurt to have him paint it too. Then you don't have to move the truck, re-clean the frame and paint it.
I'm a fan of the Chassis Saver by Magnet Paint and Eastwood products. Eastwood will have a good etching primer, then follow up with a a good paint (like their chassis paint or Chassis Saver). Not cheap, but good stuff.
And even though it will make that nice new paint look like garbage, a top coat of Fluid Film Black or NH Oil Undercoating will keep the rust from coming back. You'll want to paint first, but you'll want a penetrating oil to get in between the frames.
   / Bare metal epoxy primer for truck frame #10
If your not taking the frame off the body dont bother. There will be many places you cant sand blast and cant paint. All it takes is one rock and your paint is gone.
Woolwax or Fluid film work well, are self healing to some extent and you can spray areas you cant normaly get to.
Yes POR 15 sucks. The amount of prep work to get it to work properly is the same as normal paint..and your one rock chip away from failure.
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
1988 John Deere 2755 (A50120)
1988 John Deere...
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
2013 TOYOTA TUNDRA(INOPERABLE) (A52472)
2013 TOYOTA...
2020 International MV607 2,000 Gallon Water Truck (A50323)
2020 International...
