bar turfs?
   / bar turfs? #1
seapea
SF Bay
Kubtoa B2620
I purchased a B2620 today. I'll take delivery later in the week. I asked for R4s and the dealer asked why. I explained I'll be doing quite a bit of tillage work preparing a 1 acre field for seeding with grass so my son can do some sports on it, so I need a tire that will grip in loose dirt. However, I also need something that is also easy on the lawn because eventually I'll probably also using it for mowing; not only the sports field, but also the nice lawn around the house.
The dealer then said that R4's are really only meant for pavement and hard ground, would not grip all that much better than turfs on soft dirt, and most importantly, would rip up my lawn. When I mentioned all the TBN users that are using R4s and mowing their lawn, he claimed that they all live east of the Mississippi, and what they call a lawn is actually not much more than a field that grows grass because it rains at least once a week (no rain out here in the summer time), so lawn damage is not really a concern.
He then showed me a Kubota tire that I believe he called a "bar turf". The rear has a bar pattern similar to an R1, but is much lower profile, and the tire is wider and less rounded than an R1. The front tire is basically a turf tire, I would presume so it doesn't rip up the yard when you turn. He said the rear bar turfs would not tear up the lawn like an R4, and would still grip well in loose dirt.
Anyway, I just wanted to know if anyone else has experience with these "bar turfs". Also is anyone using R4s on what I guess you would call a manicured lawn (sodded and watered regularly).
thanks,
Chris
   / bar turfs? #2
seapea said:
IAnyway, I just wanted to know if anyone else has experience with these "bar turfs". Also is anyone using R4s on what I guess you would call a manicured lawn (sodded and watered regularly).
thanks,
Chris
Chris,
I am fairly new to TBN also and saw your posting. I know there have been postings in the past regarding comparisons between turf and Bar Turf tires. I tried to send a thread to you from a posting by RobertM in 2004 on TBN, but just don't know how to do it yet.
If you use the search feature on TBN and look for RobertM postings, and then look at the June 4, 2004 postings titled, "7610 Bar tires versus Turf tires, you'll find a pretty good review. I suspect that if you just search for the comparison between the two tires, you'll get all the information you'll need to make a decision. Dyer, retired
   / bar turfs? #3
Dyer said:
Chris,
Sorry, I just ran the search on RobertM and the comparison he did was June 10th, not the 4th, but it addreses the same concerns you had about Bar Turfs on grass, etc. Dyer, retired
   / bar turfs? #4
Bar turfs were pretty popular in this area before R-4's became the thing to have. Actually, the "bar" tires that are available on the BX series are closer to bar turfs than to R-1's. Here is a pic of some older bar turfs..
   / bar turfs?
Dyer said:
Chris,
Thanks, that was useful. You can click here for the posting you referred to.
Chris
   / bar turfs? #6
Chris
Chris,
I am tired and not paying attention. I looked at the date you became a member of TBN and felt pretty stupid trying to describe a "search" method that you would clearly know how to run.
ChuckinNH,
That Kubota with the Bar Turfs shines a little more than the rig next to it? Dyer, retired, but mostly tired
   / bar turfs?
Dyer said:
Chris,
ChuckinNH,
Actually I had trouble with the search when I included the subject you gave and RobertM's name. I always got server errors. I trimmed things down until eventually I just looked for all posts by RobertM, and then looked for the date you gave.
thanks,
Chris
   / bar turfs? #8
thanks,
Chris
Hope it was helpful. Congratulations on the purchase the
B2620 by the way. I don't know about you, but I sure hate buying something and then having to wait for delivery. When I bought mine, the dealership owner dropped mine off on his way home, so I didn't have to wait long. Have fun. Dyer, retired
   / bar turfs? #9
Wish they had those rears for a BX. Looks like that would do a buch to settle the debate...
   / bar turfs? #10
They look like they would provide a heck of a lot more traction than the turfs I have on mine. Truthfully, I have only been stuck a couple of times in the winter with the turf tires, once was my own fault and the other time was just hitting ice and sliding sideways before anything could be done. I find that the weight of the rear blade and the blower on the front, along with the 4wd, can get me through anything my needs dictate. I have considered
R4's, but always talk myself out of spending the money in favor of some other project. Dyer, retired
Deere 410L (A53317)
Deere 410L (A53317)
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
