Tires Bar Turf Tires?
/ Bar Turf Tires? #1
RhallVA
VA
Anyone use Bar Turf tires to mow the front yard? I found them excellent for loader work, but wonder if they will be too tough on the front yard in the spring! I have a B2410 with Turf Tires in front and Bar Turf in the rear. Anyone used these with or without sucess?
Thanks!
/ Bar Turf Tires? #2
The bar turfs came with my JD 670. I've not had any problems with them damaging the lawn.
Not sure how good they'd be in the snow, however...we've only got 3"-4" so far.
The 670 is pretty light, however...maybe 2200 lbs with the FEL on it.
/ Bar Turf Tires? #4
I had a 2400 with turn/bars and although I never used it to mow the lawn, I did travel over the grass frequently without undue trouble. It thought they were a good compromise for suburban use. Wen I went to heavier construction/farm use, the R4s were better. I was getting flats all the time with the turf/bars. Next time around I'll go with Ags since I don't expect to encounter the lawn at all.
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
2017 International HX620 Quint Dump (A62613)
2017 International...
