Bansil's Shenanigans begin again....
/ Bansil's Shenanigans begin again....
Thanks!
Now to today's trials and tribulations...
You know how your supposed to read and understand the manual on a piece of equipment?
And yes the wt. Limits for the FEL based on distance from pivot point....are real and a fact
You would of thunk? 🤔
So...950#'s plus bucket 3 ft from pivot point doesn't even make the pump groan, it just instantly bypasses 😅 it didn't realize or think, well actually I didn't think it would pick it up.
So I grabbed another pallet
So pallet forks mount on a QA mount will be a fab in the future...
Kept bucket low, hit a small bump and the leverage actually had the bucket tap the ground 2inches down and lift back tires off the ground :oops:
I backed up so valve stem was at 9 oclock...depressed valve stem...liquid came out...just making sure they were filled.
So I'm going to eat and head back out, finish clearing out backyard.
Mount my chain hooks and try to move the 8ft box blade up to the old goat shed and turn it into a 5ft box blade.
Happy Good Friday!
Well I mounted my chain hooks
Yes they are zombie green, I ordered safety yellow, but out of stock.
Went to move the 8ft box blade...
Well, that went over like beans in real chili...
Just like with the blocks....I wondered 🤔 how much does the damn bucket weigh?
Took off bucket and put my blank plate on it...it easily lifted it up..
I moved it up to the goat lot with intentions to cut off a foot on each side, to make a 5 ft box.
Should I try it at 7ft? It's in the back yard so it's all been cut or dug and moved
???? Let me know...I will see if I have spacers and may just try it.
Picked up some branches also
Well so far today I made a dirt pile
Came from here...worked on it today it ,and put angle on it
/ Bansil's Shenanigans begin again.... #45
I had a 6 foot box blade. It's width and weight where fine for my 37 hp tractor, but getting good with it was beyond me. I found that using the front bucket on my backhoe was a lot easier for me to smooth out the ground by back dragging with it. I traded the box blade with a guy after having it a few years.
In hindsight, it might of made a decent drag.
Spent a few hours removing old fence to reclaim pasture. The fence is laid out to the right of the tractor....under the UFO :oops:
None of us saw anything in the sky..
My helpers
Moving the roll of wire
So, wife says "I got a good commission check this week,, for the yard" Ugh, okay....:rolleyes::unsure:
Got to use the new forks again...
Both trailers are full....
The 3 of use did this load....next 50 pallets was on me as they went to buy plants....these were fkn heavy...50 pallets for a total of 150-ish...damn etsy/pinterest/etc...
Thank God I could off load them with tractor
/ Bansil's Shenanigans begin again.... #48
You're up there with the best of them when it comes to putting the girl to work as soon as she was home. 🤣
/ Bansil's Shenanigans begin again.... #49
Did you buy pallets, or are you selling them?
Nope, she did :p
She has some kind of wall of pallets, filled with dirt and plants and such....damn Etsy, Pinterest and HGTV :ROFLMAO:
Thanks, this coming weekend should be fun...
/ Bansil's Shenanigans begin again.... #51
The pallet craze seems to have run its course in my area. Seemed like everybody on FB was posting something that they had created from a pallet.
I'm leaning strongly towards using pallet wood for the wall of my back porch kitchen. The rest of the house is Hardie, so this might be a nice contrast. Or it could be a disaster.
I say go for it,
I told a couple neighbors that if the couple "problem" neighbors ask about the pallets, to tell them we are planning to get 50 hogs and this will be for the walls for their enclosure :ROFLMAO:
Looks like I never posted these little guys yet :unsure:
So back into chickens again after a 6 year hiatus.
They out grew the 1st box in just a week.
So I made a new cardboardboxominium for them...just like the Jefferson's
they are moving on up!
Definitely cleaner this morning
This weekend I need to finish digging this out, it is the interim housing while I fix/modify etc to their bigger coop.
Egg opening
I have a couple trees to cut down
Then figure out exactly how to move it, I did use the FEL to get front off the ground, after I remove the trees I may tack a pc of angle iron to one of my QR plates, lift the house side up and then use straps around the front to pull it up
It wasn't raining last night so I grabbed the tractor and collected the rocks from planting 10 more fruit trees on Sunday
Used bucket to lift and move the coop to the right and square it up, left it on spare wheels.
So then I tacked a PC of angle on a QR plate, and set it under the coop end, laid a PC of 1-1/2 square x 3/16 wall across angle to support the whole end.
Couple straps around the base and then over the top of coop and rops, then attached the strap to the BH.
Got the front a couple inches of the ground....and away I went.
/ Bansil's Shenanigans begin again.... #58
That's a really good move, using the backhoe to support the coop. Just something real simple that I would have never thought to do.
;) use all the leverage and help you can...
2011 CATERPILLAR 279C SKID STEER (A65056)
2011 CATERPILLAR...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
CAT 320 CL GP Bucket (A68134)
CAT 320 CL GP...
2014 FREIGHTLINER CASCADIA TRI -AXLE (A67714)
2014 FREIGHTLINER...
