Bank stabilization with vegetation in Mississippi
   / Bank stabilization with vegetation in Mississippi #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
All around my shops, house, driveway I've fairly steep slopes, generally from 20' to 50' in length.
All of them have become overgrown with what looks like 30 years of Mississippi mixed "let it grow, ignore it" growth. Now it's mostly a mix of Sweetgum (10" to 20" DBH), pine 6" to 20" DBH), some cedar (6 to 14" DBH) and I'm slowly working on clearing it out. But I'd like to plan on replanting with some low and slow growing dense shrub that would shade everything else out to prevent the pines etc. from coming back yet still "hold the ground" and stabilize the slopes.
I don't want grass to mow or more trees to cut.
Any suggestions?
   / Bank stabilization with vegetation in Mississippi #3
Pines and cedars aren't likely to grow back from the stumps, at least. Are you planning on painting the gum stumps with roundup or triclopyr as you go?
Yes, and spot spraying anything that show that I don't like. There are also a lot of poison ivy vines.
   / Bank stabilization with vegetation in Mississippi #5
Finding things to outcompete poison ivy will be tough.
That reminds me, I have some spot spraying to do...
   / Bank stabilization with vegetation in Mississippi #6
I don't know any plants that grow dense enough to crowd out trees, but is low growing. Mowing required at least once a year
   / Bank stabilization with vegetation in Mississippi #7
kudzu ?
I guess I should have modified "low growing" to 5 ft high or less.
Sort of like some Arborvitae.
   / Bank stabilization with vegetation in Mississippi #9
Any suggestions?
Don't know what DBH is but why remove them. They are keeping the banks stable and keep the corrosion down, if that is needed in that case.
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2013 HINO 338 26FT BOX TRUCK (A59575)
2013 HINO 338 26FT...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58216)
HYDRAULIC TILTING...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
LENNOX 4 TON AIR CONDITIONING UNIT (A58376)
LENNOX 4 TON AIR...
