BanjoDon
   / BanjoDon #1
BanjoDon
Ford 8N several, Ford diesel
Hello, I'm new to the forum. Have several tractors, Ford, 8N's mostly and a newer diesel New Holland Ford.
Having trouble with the diesel quitting like it is running out of fuel but it has plenty. Friend says I have algae in the fuel.
Is there something I can do to solve the problem if it is algae. Tractors sit a lot and I use them for mowing now at various properties. I'ed appreciate any suggestions.
Thanks, Don
   / BanjoDon #2
:welcome:
To TBN Don. You have come to the right place to get answers.
I had that problem last year. I got some Bio-Cide and put a little in each tankfull. No more problems.
Before my first treatment of my diesel fuel, I changed the fuel filter and cleaned the bowl.
It doesn't mater which brand of treatment you use as long as it treats algae.
   / BanjoDon #3
Hi Don - welcome to TBN and the forum. There are many biocide/algaecide products that can be added to your stored diesel that will help with the algae problem. The names I hear most often: Power Service and Centramatic. Google either of these two products or google "algae in diesel" and there will be article on treatment.
I would like to give you first hand experience but, knock on wood, I've never had algae in my fuel. Other will likely be along and give more specific advice.
Suggestion - update your profile and let us know where you are located.
   / BanjoDon #4
G'day Mate and welcome to TBN from Downunder.
As oosik suggests... we need to know where you are (generally) in the world in order to better assist you. For example; there's an Australian product (Fuel Doctors) that is ideal to help you. I've used it, highly recommend it and I didn't even have to change the fuel filter.
Enjoy the site.
   / BanjoDon #5
:welcome: to TBN.
Last time you change fuel filter?
Try...get rid of fuel in tank ,blow out fuel line change fuel filter maybe little fuel additive.
   / BanjoDon #6
Hi Don. Welcome to the forum! :welcome:
:tractor: I'm going to move this thread over to our New Holland section.
   / BanjoDon #7
Get a catch bucket, close the fuel valve, remover the discharge hose after the filter assembly, put the bucket under the hose and open the valve . See if you get a constant stream of fuel. You might have also clogged fuel filter.
JC,
2023 Kubota U27-4 (A50120)
2023 Kubota U27-4...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
Rain-Flo Vegetable Transplanter (A50120)
Rain-Flo Vegetable...
2011 FREIGHTLINER M2 (A52472)
2011 FREIGHTLINER...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
