banjo fittings
   / banjo fittings #1
Tim D
LaGrange Missouri
860 Ford,Farmtrac 675 DTC
I am looking for a more reasonable price for the banjo hydraulic fittings that fit the early 60 models 2,3,4000 tractors. $47 dollars each at local dealer.These fittings went on the remote valve and had the flow through bolt and the fitting could be positoned any direction. The fitting would then let you connect directly to NPT. I only need the fitting, not the bolt. Ford part # I was given was 311891. THANKS
   / banjo fittings #2
Did you check your CNH dealer? I have gotten them from mine. IE.. the banjo fitting that goes to female pipe thread. I don't recall them being 50$ each there..
FWIW, I have used 3/8 ord fittings in those valves too.. some of them are tapped for orb.. YMMV.
soundguy
   / banjo fittings
The Ford/New Holland dealer is where I got the price. I think that is way to high for what I think is a very simple machined fitting.
   / banjo fittings #4
They used to use them on English cars. Try an auto parts store.
   / banjo fittings #5
they must have went up.. when I priced them they were about 23$
soundguy
   / banjo fittings
I might try another dealer to see if the first dealer I checked with was trying to put it to me. If I get a quote of the same price or cheaper, I will know.
   / banjo fittings #7
good idea.. never know what the markup at that one dealer is.. might be huge..
soundguy
   / banjo fittings #8
soundguy
Soundguy,
Have you seen doubling up two banjo fitting along with a longer banjo bolt tying them both together. Reason I am asking is , if a guy can use it to make a hyd remote using it and some 3/8 hose wit quick connect fitting. On my 1700 connection can be upstream of main pressure relief as well.
JC,
ps. Sorry if I'm hijacking this thread a bit. I thought it might be a valid question to ask.
The discharge line going to lift spool valve and relief device. The square head bolt opens up to the rear diffy so it can be used as return.
what do you think? I have a hard time finding aux hyd block .
   / banjo fittings #9
hmm.. I guess anything is possible. using the copepr crush washers. as for the hollow bolt.. I guess you could drill your own.. etc.
might be less trouble to break the hard line though.. all depends on what your braze/welding/fabrication skills are though..
soundguy
   / banjo fittings #10
soundguy
As soon I asked I Google the subject a bit and below is what I found. i can cut the discharge pipe off and put a compression tee in there but hate to modify something that I can't reverse. Hyd block the best way to go. look at the link below.
JC,
Goodridge Chrome Double Bolt for BMW, Ducati and Suzuki - DennisKirk.com
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
Guard Rail Joints (A51692)
Guard Rail Joints...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
Gravely Compact Pro Zero Turn Mower (A53117)
Gravely Compact...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
