Tim D
Bronze Member
I am looking for a more reasonable price for the banjo hydraulic fittings that fit the early 60 models 2,3,4000 tractors. $47 dollars each at local dealer.These fittings went on the remote valve and had the flow through bolt and the fitting could be positoned any direction. The fitting would then let you connect directly to NPT. I only need the fitting, not the bolt. Ford part # I was given was 311891. THANKS
