Ballasts on subcompact tractors/ loading tires.
   / Ballasts on subcompact tractors/ loading tires. #21
so...how much weight can foaming the front tires add? is it cost effective?
I would think a scoop of dirt in the loader would be better.
The primary reason to foam tires - puncture resistance. Adding weight to rear drive tires a bonus side effect, adding liquid weight usually discouraged, dought you'll ever find bolt on iron weights for front tires.
   / Ballasts on subcompact tractors/ loading tires. #22
Good morning,
I tried to search but I couldn't find my answer. I own a GC1723 MF subcompact tractors, and have been getting conflicting information on the benefits of tire ballasts for it.
Multiple MF dealers have told me that it's not worth the trade off. One dealer mentioned the wheels can have a tendency to spin in the tire, another said it doesn't make much difference and using proper ballasts on the front and rear attachments is the way to go. I also have been in situations where there isn't enough power from the tractor to push me up an incline, and I would assume that a weighted tire/wheel is going to create more resistance.
When shopping for equipment, the Kubota dealer offered to fill the tires for free without me even mentioning it, which makes me assume that this is very common and must serve a purpose on the subcompact lines. I see many other subcompact owners load their tires as well.
Is loading our tires on the subcompact line actually worth the time and energy?
I loaded the OEM R4 stiff sidewall tires on my 2400 initially. The tires are rated for about 2500# each at their rated pressure....18 psi as I recall. 2 tires =5000# and the whole tractor only weighs 1800 + loader.......add that to stiff sidewalls and stiffer than necessary coil springs under the seat and the load on your back is BRUTAL on dry, heavy clay soils.
I filled mine to about 70% tire height and dropped the pressure to less than 10 lbs in an attempt to get a soft ride with the OEM tires. Had 2 problems, one being tires spinning on the nice new, shiny, slick wheel and the other was that the weight of the fluid in the tire tended to put unequal pressure around the circumference of the rim meaning you had weight + air pressure at the lower part and just air pressure at other parts.
Tires would separate from the wheel under working conditions. After spending hundreds of bucks on tire and wheel combinations and seats, I spent another couple hundred or so on wheel weights, actually 2 sets (4 weights, running about 135# per wheel.....equivalent to about 19 gallons of water which no way would the tire accommodate that volume.
The rest of the story is I bought a suspension seat $100+, actually 2 as the first one was like MF seats back in the '60's and was essentially a padded cup...too narrow for my hip bones (suspension part worked great), and the second was flat, more conventional and worked, for another $100+. Then I thought turf tires at 4 ply would give me a soft ride, but the only size available had stiff sidewalls...finding out after the purchase...another $375 down the drain but wait, had to downsize the wheels as the OEM were 16.5" which is a heavy duty tire size...like 12 ply Skid Steer tires and to get a turf and later a set of Farm lug (R1) tires had to go to 16" wheels, another $300ish down the drain.
Finally, the 8x16 4 ply R1s, (soft sidewalls finally) at 10 psi with the weights mentioned above and with the suspension seat, gave me a reasonable ride. But with out an implement attached, it took another 230# in the seat (me), to keep the rear tires on the ground with a full bucket.
On the weights as an offset for heavy FEL work, my 2400 has more HP and lift capacity than the frame can tolerate.....in short, you need something on the rear to hold the rear tires on the ground if you fill up the bucket with dense material, like rocks, or wet sand. So add weights, and yourself, or have an implement on the 3 pt when doing heavy work.
   / Ballasts on subcompact tractors/ loading tires. #23
Fronts are 18 x 8.50 x 10, foam fill adds 20-25lbs per tire. Also never have to worry about flats again. Farm has been in the family for 150+ years, there is lot of scrap metal around.
The FEL is used as well as the rear blower for clearing snow, can't really use it for more ballast.
   / Ballasts on subcompact tractors/ loading tires. #24
My Mitsubishi MT372 has loaded rears as well as weights on the back side of the wheels. It also has weights on the front bumper. Wouldn't be able to do half the stuff I do with that tractor without them I recon. It's only 15 hp.
   / Ballasts on subcompact tractors/ loading tires. #25
This is the data for my MF tractor tires regarding the weight of RimGuard added to each tire:
9 gallons of Rim Guard for each rear tire = 97 extra pounds per tire, tire brand/size is Titan Trac Loader R4, 26 x 12.0-12NHS.
4 gallons of Rim Guard for each front tire = 43 extra pounds per tire, tire brand/size is Titan Trac Loader R4, 18 X 8.50-10.
The total cost was about $100 in 2011 by dropping off the tires/wheels to the RimGuard installation tire shop.
KC
   / Ballasts on subcompact tractors/ loading tires. #26
One thing I fail to understand and that is.. It's a sub compact tractor so it will do a sub compact job right? If you want a real tractor buy one not a tiny one and then want that tiny tractor to do a big job.
You don't go to a barn fire with a squirt gun. Same applies here.
   / Ballasts on subcompact tractors/ loading tires. #27
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Neophyte tractor shoppers are often intimidated by instability of tractors with small front wheels and large rear wheels, therefore frequently purchase tractors too light, too small for long term satisfaction. Often subcompacts are gussied up with wheel weights, SSQA FEL bucket and grapples, bucket hooks, work lights, etc. making a subcompact into a big-boy's tractor in the newbie's mind. The options are lipstick on a baby pig.
Bare tractor weight is the tractor metric that best defines tractor capability..
Five reasons owner/operators trade up from Subcompact Tractors:
More tractor weight.
More FEL lift capacity.
More ground clearance.
Three-range (3) HST (Lower LOW, Higher, HIGH) ~~ rather than two-range (2) HST.
More tractor power.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Exactly. You put lipstick on a pig, it's still a pig.
   / Ballasts on subcompact tractors/ loading tires. #28
Don't get me wrong, I'm tickled you buy them, especially Kubota's. Keeps my dealers light on and his shop help paid, but I'd never have one and never have either because I know the difference between a suburban wannabe toy and a real working tractor.
   / Ballasts on subcompact tractors/ loading tires. #29
OP, if you haven’t already, head over to the MF subforum, for all the advice you’ll need, without all the simpletons ****ting in your thread about it not being a real tractor and other overplayed tropes.
   / Ballasts on subcompact tractors/ loading tires. #30
Good morning,
It seems to depend on your location, topography and what you do with your tractor. If you are pushing or carrying dirt or tilling you will need ballast. If you have hills that will make the tractor tippy, weight in the tires works great for stability.
It may slow your top end speed a quarter mile an hour when running the road.
I have been putting Rimgard in since 2010 when I got my 45 HP CUT. Previously I had 30+years of larger garden tractors and I put Calcium Chloride in the rears mostly because of the dirt work I was doing. Now that I just mow with my garden tractor I put windshield washer in the rears plus cast wheel weights on because of hills and ditches I mow with.
I cannot see any downside to putting fluid in unless you tear tires up often making changing tires a little more difficult. I just replace my rears after ten years so I just reused to fluid with new tires.
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
Cargo Van (A59230)
Cargo Van (A59230)
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
