ballast resistor / coil x-ref chart
/ ballast resistor / coil x-ref chart #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I used to have a link to a gmvehicle chart that showed what value ballast resistor matched what ignition coil.. also listed years used and ohm value.
I have misplaced it.. anyone know of a link to similar? Even a mopar one may work, as I noticed many of the ohm values totaled 2.8 - 3.2 On a wide range of applications.
any help is appreciated, thanks
Soundguy
/ ballast resistor / coil x-ref chart #2
Soundguy
You're right about the resistance values. I recently upgraded a frok truck from 6 to 12 volt and replaced the coil. First I tried a coil with out included resister and managed to burn it up. Then I went to a coil that did not require an external resistor and all is well. Why not just change coils. I used coils from 70 vintage Ford Falcon's because they were the cheapest about $11 at Advance Auto. Makes wiring much simplier.
Andy
I pretty much always use NAPA IC14SB.. a true 12v coil.. 3 ohm.. etc.. However.. I'd like to get my hands back on that cross-ref chart cause it had all the values of ballast resistors.. resitor R# and what gm coils they matched.. also convieniently gave me the coil ohm values.
I occasionally do custom ignition coil based projects.. and having a chart of coils helps me choose one for my voltage range without using a balalst resistor.. I.E. .. I drop supply voltage to match the coil instead of using a high supply voltage, and a coil, and a ballast.. as the extra power is just disipated as heat.. etc..
Soundguy
I've been searching for it too.. bummer.. I'll bet the guy took his sight down.. etc.
thanks for the effort!
Soundguy
2002 POLAR TANK (A60736)
2002 POLAR TANK...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2005 LEEBOY 685B MOTORGRADER (A62129)
2005 LEEBOY 685B...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
