Ballast on the Front??
/ Ballast on the Front?? #1
schole
Ontario, Canada
Kubota L3400
Should I add ballast to the front end of my tractor (L3400)?
I have been extremely pleased with the improved performance of my FEL after making Soundguy's concrete ballast for my 3ph.
However, I find that the front end seems to want to rise at even a relatively small load while grading forward with the FEL in the float position leaving only the rear tires on the ground. It sets right down if I lift, of course, but I would like to be able to push on forward with all 4 wheels gripping as I peel up a larger amount of soil with the loader in the float position. This is not an issue if I don't use the float, however, I don't get quite as slick a job on the first pass.
Do you all find that you need a few pounds of removable ballast thrown on the front end too?
Thanks in advance,
Shawn
/ Ballast on the Front?? #2
I'd say it's a matter of clearance. Many FEL equipped tractors don't have enough room behind the FEL to install any removeable weights. Those that still feel they need extra weight, ballast the tires - which of course, is pretty much permanent.
//greg//
Thanks for the response, Greg.
I guess I was hoping to hear if anyone else has had this experience after adding rear ballast and then considered weighting the front?
Shawn
/ Ballast on the Front?? #4
The rear ballast is doing it's job & giving your rear wheels a good bite, which is lifting the fronts up. All your weight is being transfered into grip already.
Please give your tractor a break, and don't break it. I would never want front weights on a tractor with a loader, that poor front axle has enough to do.
--->Paul
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
John Deere MX10 (A64119)
John Deere MX10...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2023 KMC 3pt 6 Row Rolling Cultivator (A64119)
2023 KMC 3pt 6 Row...
Hydraulic Bottle Jack (A61573)
Hydraulic Bottle...
