Tires Ballast in tires
   / Ballast in tires #1
kootenai
North Idaho
'07 Kubota L3400. Woods: Tiller, Back Blade, Box Blade, Backhoe
Ballast in tires. How do I know if it is in there? Hopefully a simple question. I am looking at a L3400 and the seller does not know if there is ballast in the tire. How do I easily answer that question? Push on the valve stem and liquid comes out?
   / Ballast in tires #2
I'll be curious to know if there is a better way. That's what I have always done. If you get just air, then there is no ballast. I can't think of another way, but I have learned a lot on this forum. I'll be right here watching with you.
   / Ballast in tires #3
Not sure how big the tractor is but if I rock the WD45 I'm working on or my 640 I can easily hear it sloshing. (Engine is off of course) I would just poke valve stem.
Easiest way is to try to lift it haha just kiddin
   / Ballast in tires #4
Just press in the valve stem with the tire at 6 o'clock (at least not at 12:00 o'clock) and see what comes out. Of course you can see the fluid level on a cool high humidity morning. The portion of the tire with fluid will have moisture on it and the upper portion of the tire will be dry. you can also detect the fluid level by "thumping" it with you knuckles like "thumping" a watermelon and listening for the change in density. This requires some experience and practice.
James K0UA
   / Ballast in tires #5
I would remove the valve stem cap and examine the valve. If you see stuff that looks like and smells like grasshopper vomit, then they are loaded.
   / Ballast in tires #6
+ 1 on Push the valve stem with it between 4 and 8. Fluid will come out. Some fluids can cause a chemical burn so be careful (calcium chloride).
   / Ballast in tires
Excellent! I see there is a hierarchy of materials for ballast. First, calcium chloride; next, beet juice; and finally, Grasshopper vomit. I believe it is necessary to wear a hazmat suit when handling the vomit of grass hoppers so I may hire this one out.
   / Ballast in tires #8
Weight in tires is not ballast. Ballast is counter balance. You cannot get counter balance without weight behind the rear axle.
   / Ballast in tires #9
Funny, my OM has a section on adding liquid ballast.
There are different types of ballast, for different reasons, ie front ballast.
Stability on slopes, is one benefit of loaded tires.
I will agree that to best counter balance something like a loader, the weight must be aft of the rear axle.
Weight boxes, hung on the 3PH can be filled with grasshopper vomit, but should be covered.
Best, Bill
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
Ficklin Mod. 4500 Gravity Wagon (A50514)
Ficklin Mod. 4500...
Test Button (A47384)
7 Shank V Ripper (A52128)
7 Shank V Ripper...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
