Ballast Ballast in the tires?
   / Ballast in the tires? #1
MDL
Kubota BX23
Is there a way that I can check to find out if my tractor has ballast in the rear tires?
   / Ballast in the tires? #2
Yep...
Depress the valve stem... if salty water sprays out.. or some other liquid besides air... you got it... /w3tcompact/icons/wink.gif
   / Ballast in the tires? #3
Mark, I would find out WHAT is in there no matter what. As Johns suggested, it might be salty, ie sodium chloride. If that wasn't done right or is just low, it will really corrode your wheels. (there are plenty of posts concerning that...) I used non toxic antifreeze for mine.
The Yanmar manual calls for the fluid to completely cover the wheels, so that they do not come in contact with air.
   / Ballast in the tires? #4
How do you actually fill the tire with the antfreeze/water mix? I have an air compressor, how do I pump the fluid in?
   / Ballast in the tires? #5
My farm supply store sells an adapter that fits a garden hose, or pump. NAPA also sells one, for about $18 (mine was $6)
They have an air bleeder to let you bleed the air that is being compressed by the liquid.
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
