Ballast Ballast in the tires?
   / Ballast in the tires? #1
MDL
Bronze Member
Kubota BX23
Is there a way that I can check to find out if my tractor has ballast in the rear tires?
   / Ballast in the tires? #2
Yep...
Depress the valve stem... if salty water sprays out.. or some other liquid besides air... you got it... /w3tcompact/icons/wink.gif
   / Ballast in the tires? #3
Mark, I would find out WHAT is in there no matter what. As Johns suggested, it might be salty, ie sodium chloride. If that wasn't done right or is just low, it will really corrode your wheels. (there are plenty of posts concerning that...) I used non toxic antifreeze for mine.
The Yanmar manual calls for the fluid to completely cover the wheels, so that they do not come in contact with air.
   / Ballast in the tires? #4
How do you actually fill the tire with the antfreeze/water mix? I have an air compressor, how do I pump the fluid in?
   / Ballast in the tires? #5
My farm supply store sells an adapter that fits a garden hose, or pump. NAPA also sells one, for about $18 (mine was $6)
They have an air bleeder to let you bleed the air that is being compressed by the liquid.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
