Ballast for 4720
   / Ballast for 4720 #1
popsie
Southern ,ohio
john deere 1026r, john deere 2030, ford 8n,Massey ferguson 230
Does anyone know if I can load tires with rim guard and have 2 wheel weights on each rear tires at the same time?i have r4 tries. H180 loader.
   / Ballast for 4720 #2
popsie
Don't know of a reason that it wouldn't work well for you.
   / Ballast for 4720 #3
I have three 110 lb. weights on each rear and filled with WWF a drum in each tire. No problems so far with the 4520.
   / Ballast for 4720 #4
This is what is listed in the H180 loader operator's manual:
All of the following requirements are necessary to prepare the tractor for loader operation:
H180 MSL:
1600 mm (63 in.) or greater rear tread setting.
Rear tires filled with liquid ballast.
Four rear wheel weights.
380 kg (836 lb) minimum 3-point hitch ballast.
H180 NSL:
No rear wheel weights
For fluid filled rear tires: Fill tires 3/4 full using a calcium chloride mixture of 1.6 kg (3.5 lb) per 4 L (1 U.S. gal) of water
2010 Ford Edge Limited AWD SUV (A51694)
2010 Ford Edge...
Towable generator (A52377)
Towable generator...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
Auger for full size skid steer (A53421)
Auger for full...
KUBOTA ZD1211 (A53084)
