Ballast Bucket
   / Ballast Bucket #1
catdozer
Platinum Member
john deere
Came across this old HEAVY John Deere bucket and that we never use anymore. and well i was figuring i could make this into a nice ballast box or ballast bucket! :D so i mounted the bottom hooks and made it fit the Imatch hitch. just have to make the toplink tomorrow. it weights abut 400 lbs empty so its going to get a layer of concrete on the bottom then filled with some old cast iron wheel weights, then fill with sand and top off with a cap of concrete and form a tray to put chains etc in. thinking im going to end up with about 900 to 1000 lbs of good ballast :thumbsup: hope this works well!! :licking:
   / Ballast Bucket
forgot pictures :p :tractor:
   / Ballast Bucket #3
Looks good, will make a handy carrier if you need to move alot of tools etc. Like having a trunk. looks big enough I'd leave it with just loose ballast so you could dump it if you need the storage space.
I made a contraption where I can put a regular JD front bucket on my I match too. Haven't really had a need for it yet.
JB
   / Ballast Bucket
Yep all finished I can't believe how nice it is. Got about an hour today of cleaning trails, and it was not tippy with the grapple on, here's what I did from start to finish, step 1- place 1 80# bag of quick crete, 2- put moist sand in, 3- put 2 large HEAVY rocks in, 4- put more sand in and metal scraps wet down and compact. 5- mix 3 more 80# bags and cap with concrete. But always put the PVC coupler in first, so I dug a 4in area out put a 4in coupler so can a pipe on or keep flat. It is very heavy!!! Just have to weld some stands on to keep it from rolling back.
   / Ballast Bucket
Here it is all finished, went into the woods with grapple it performed quite well, I thought I would loose visibility but I just lowered it and all was fine. Carrys tools quite well.
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2020 Kubota Sidekick RTV-XG850 (A47384)
2020 Kubota...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
