Ballast box height on three point hitch
   / Ballast box height on three point hitch #1
Teikas Dad
Live Free or Die
Kubota B3200
I searched but couldn't find the answer. There are plenty of posts on building ballast boxes and buying ballast boxes, but I couldn't find any posts dealing with where/how high or how low to position a ballast box mounted to a TPH. I just bought a Kubota ballast box for my B3200 and hooked it up today. Loaded it up with 350lbs of sand (in 50lb bags).
My question is, what is the best position to carry the ballast box at? Is it better lifted all the way up, or keep it as close to the ground where there is no interference with the ground or midway? With my limited physics education it would make sense to me that carrying lower and farther away from the tractor would extend the moment arm and maximize the weight effect while keeping the tractor CG lower. Raising it up all the way brings the box slightly closer to the tractor, reducing the moment arm and also raising the CG on the tractor. Or, am I overanalyzing things? Does it really make any difference how high or low the box is?
   / Ballast box height on three point hitch #2
Lower is better, but it drags the ground on inclines and rough terain. I usually have mine about half way in the middle unless I need to go up steep hills or loading on the trailer.
   / Ballast box height on three point hitch #3
The only concern I would have is that a ballast box does raise the CG when it is raised all the way up. When operating on steep hills that could be a concern. Other than that I can't see that it makes a difference on the height. I keep mine raised all the way up but only use the ballast box when moving snow on fairly level ground.
   / Ballast box height on three point hitch #4
The great thing about having it on a three-point is that you don't have to settle on one position. But yeah, I would say your logic is sound. I would want it riding as low as possible without scraping.
   / Ballast box height on three point hitch #5
That is what I do and recommend.
   / Ballast box height on three point hitch #6
Lower is better. As noted above, if it drags, lift it.
What are you doing that needs the extra weight? That may also determine the best answer.
40'' root grapple (A53421)
40'' root grapple...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
Heritage HC72 Rotary cutter (A53473)
Heritage HC72...
2009 INTERNATIONAL PRO STAR+ (A53843)
2009 INTERNATIONAL...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
