Ballast Box for 3510i?
   / Ballast Box for 3510i? #1
redfoxco
Branson
Hello,
I'll be doing a bunch of loader work this week. I do not have a ballast box yet and need to purchase one or make one.
So, how many lbs. of ballast is typically sufficient for this type of work?
Thanks!
   / Ballast Box for 3510i? #2
I would also look at filling your back tires. I had mine done for around $300 and it added about 800 lbs.
   / Ballast Box for 3510i? #3
What i did for a ballast box is made mine......I took a 36" sona tube and put in a cross bar horz. and flat bar vertical so that i could weld pins for my 3point connections. I then fill it with 10 bags of concrete with each bag being a 80lb bag. with the metal that i put into the concrete to add internal support....i have about a 850lb ballast box that i can pick up as needed and sit aside out of my way when not needed.
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
(APPROX 50) 2" X 2" X 98" TUBING (A51247)
(APPROX 50) 2" X...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
UNUSED CFG INDUSTRIAL MH12R EXCAVATOR (A51247)
UNUSED CFG...
2002 CATERPILLAR 973C CRAWLER LOADER (A51246)
2002 CATERPILLAR...
