Ballast Box for 3510i?
   / Ballast Box for 3510i? #1
redfoxco
Branson
Hello,
I'll be doing a bunch of loader work this week. I do not have a ballast box yet and need to purchase one or make one.
So, how many lbs. of ballast is typically sufficient for this type of work?
Thanks!
   / Ballast Box for 3510i? #2
I would also look at filling your back tires. I had mine done for around $300 and it added about 800 lbs.
   / Ballast Box for 3510i? #3
What i did for a ballast box is made mine......I took a 36" sona tube and put in a cross bar horz. and flat bar vertical so that i could weld pins for my 3point connections. I then fill it with 10 bags of concrete with each bag being a 80lb bag. with the metal that i put into the concrete to add internal support....i have about a 850lb ballast box that i can pick up as needed and sit aside out of my way when not needed.
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
2023 John Deere Z994R (A50123)
2023 John Deere...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
WESSEX CRX 180 LOT IDENTIFIER 267 (A53084)
WESSEX CRX 180 LOT...
