BALLAST BOX BUILD
/ BALLAST BOX BUILD #21
Here are a few pics of my box before paint. I was planning to paint it the way it is,but a friend and coworker who knows bodywork offered to "mud" the welds and spray it for me. So I went to the JD dealer and bought a quart of paint,thinner and hardener.......70.00...ouch! Paint wasn't bad,the hardener was the most...40.00!! Enough for a gallon though.
I made the box out of leftover 1/2"x12" cold rolled. The box tubing is 1-1/2 square with 1/4" wall. The pipes are 2" schedule 40. The pieces of angle are 3"x3"x1/2". I cut 1" off so it would be flush with the edge. The box measures 24" wide,18" deep,and 24" high. The box weighs 380lbs......empty!!
For the side pins, I'm using 1"x5-1/2-8 bolts with a piece of 1" schedule 40 pipe over the bolts for bushings. The OD of the pipe will give me just about 1-1/2". I cut the threads off a bolt and drilled a hole in the end for a 7/16" locking linch pin for the top pin. I also added a piece of 3/4"x3"x4" inside the box to give me 1-1/4" for the threaded side holes.
Comments good or bad are welcome:)
Greg
Great job on the box!! I'd call it first class welding, So, when are you coming to the Virgin Islands ( St Croix )?? I have a Miller 301 trailblazer welder that I bought as a back up generator for my house. We have been known to loose power for weeks when a hurricane passes by to visit, so I decided buying a generator was a waste of time because they just sit there waiting for the next outage. But A welder!!!!!! yepppppy!! I can learn to weld!! and this way the machine stays maintained for when you need it most.
I will let you use it to build my BB when you get here and I will kick in as many deep sea fishing trips as you can stand as a bonus!! Soooo!! question is!! When ya coming down???? I need a good welding instructor!!
Wooden
/ BALLAST BOX BUILD #22
Nice job making my 55 gallon drum ballast weight look pitiful. Seriously though, nice job.
/ BALLAST BOX BUILD #23
I know I live close...... :) Can u beat the JD prices....???:thumbsup:
/ BALLAST BOX BUILD #24
Wow, that is a super ballast box you built, :thumbsup: !!! KC, :D :D :D
Decorative Mermaid Light Post (A61574)
Decorative Mermaid...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61572)
2024 Kubota...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
Caterpillar 350/350L Excavator Service and Parts Manuals (A63117)
Caterpillar...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
Adams Weight Hopper (A63688)
Adams Weight...
