Ballast Box B8160 quick hitch compatible?
   / Ballast Box B8160 quick hitch compatible? #1
SLIMSHADIE
Central, IL
BX25D
As stated, is the ballast box B8160 compatible to a 3pt quick hitch? Anybody using this combination?
   / Ballast Box B8160 quick hitch compatible? #2
That design Kubota ballast box fit my BX2660 3 point in 2009. But now, on my B2620 with a Quick Hitch, I can not make it fit since the dimension is so narrow. Thus, I remove the QH when the ballast box is needed. If another attachment, such as the Box Blade etc. is mounted, I use them for ballast, unless working space or more ballast weight is a factor. Maybe some of the more capable TBN members can fabricate a solution.
Cheers,
Mike
   / Ballast Box B8160 quick hitch compatible? #3
It is NOT compatible. The L series ballast box does not work with a quick hitch either because of the way the top connection is made. I was able to use the quick hitch on the bottom pins but I use a chain on the top so that kind of defeats the purpose of the quick hitch but it works for me.
   / Ballast Box B8160 quick hitch compatible? #4
4shorts has a video where he modified one to be quick hitch compatible.
A separate subject, but I'm going to be making one that is QH compatible and uses a 55 gallon drum and a draw bar. The draw bar can be removed just in case I ever want to use it for something else.
   / Ballast Box B8160 quick hitch compatible? #5
No.
wrooster
   / Ballast Box B8160 quick hitch compatible? #6
In 2009 I had a set of "EZ Hitch" that had the same problem that the above PATS has. The company rep said that I could saw that top interference off, as it would then slip in there. Well that would defeat the usability of the EZ Hitch with other implements. So I just manually hooked up the box , since it was empty and not too heavy at that point. Now with the Quick Hitch I do the same thing, but have to take the QH off.....:thumbdown: Fortunately, that doesn't happen that often. Hope this helps.
Cheers,
Mike
   / Ballast Box B8160 quick hitch compatible? #7
I've bought 3 different sets of quick hitches. One was Pat's which I sold and two other different sets off e bay that were under $100 that I prefer. They don't have the "thing" sticking up and easy on and off. I even use one set upside down that comes down over the attachment pin and locks on.
   / Ballast Box B8160 quick hitch compatible? #8
Can you post which ones you like better. I'd like to get my dad a set, but would like a little cheaper...
   / Ballast Box B8160 quick hitch compatible? #10
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2022 Polaris General 1000XP UTV (A50514)
2022 Polaris...
2006 Cadillac Escalade AWD SUV (A50324)
2006 Cadillac...
Tarter 4' 3 pt Box Blade (A50515)
Tarter 4' 3 pt Box...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
