Baling with a compact - minimum size?
   / Baling with a compact - minimum size? #71
since we will have to be compairing new and old.. some of the semantics don't apply straight across the board. If you look at hp and weight.. the 3k is much closer to a CUT of today.. than a utility model of today.. vs what it was designed to be back in 65 when it was new.. etc.
Soundguy
Farmwithjunk said:
I've owned a couple 3000's. One was bought new in 1973 and stayed with me until 2 years ago. They were (a) "pre-compact tractor" era, (b) adjustable track width to accomodate row cropping to a degree, (generally NOT a feature emphsized with a traditional "compact tractor" of today) and (c) considered a mid-sized utility tractor in their day. Ford touted them as a general purpose utility tractor for small or large farms in sales brochures of the day. In the 60's and 70's, many small farmers still used 35 to 45 hp tractors as their primary "big tractor". The 3000 wasn't even the smallest of Fords utility line-up "back in the day". Long and short, they were marketed primarily towards small farmers as "farm tractors".
A 3000 may compare in hp and to some degree, in physical size to some of todays bigger compacts, but they are a tried and true utility tractor from a past era.
   / Baling with a compact - minimum size? #72
Soundguy
Utility tractors of ANY generation are still utility tractors. What constitutes a utility tractor isn't so much physical size or horsepower, but it's intended use. The 3000 was and still is a general purpose utility tractor. The fact that a utility can do many of the same functions as a compact or vice versa, there are still a good many fundamental differences. There's also still a vast number of utility tractors built today that aren't any bigger, and in some cases, even SMALLER than the 3000. The size and horsepower range of what constitutes a utility tractor has expanded upwards along with the times, but still takes in those smaller general purpose tractors too. But in the end, a tractor is a tractor is a tractor and I suppose we can call 'em anything we want, just like we can USE 'em for whatever we want.
Sorta like the age old question of what is a pond and when does it become a lake?
   / Baling with a compact - minimum size? #73
I'll be the first to admit, that Ford 3000 will probably still be going when my 5030 is in the scrap heap. Its is simply built stronger where it counts for farming. Pull the axles and you'll likely see planetaries and large axle shafts. The gears in my Kubota are probably just big enough to do exactly what was needed, I'd bet the 3000 has oversized square cut gears and may have shared its tranny with a larger machine.
I know farming with a CUT can reduce its lifespan but shoot, most compacts die a mundane death of parts going obsolete with low hours on the clock at an old age.
   / Baling with a compact - minimum size? #74
I not going to argue with you.. It's pointless.. as many of us here know.... but if you want to split hairs.. get the guy to read the model ID code off the 3000, and let FORD tell you what it was designed for, when it rolled off the assembly line..... unless the 2nd digit is a '4'.. it is not a utility tractor. I'd bet that the 2nd digit is a '2' meaning it is an agricultural all purpose machine. ( Vs Highway, LCG, RICE, Row Crop, Vineyard, NF, Utility, or industrial ).
soundguy
   / Baling with a compact - minimum size? #75
soundguy
Let's see... The POSSIBILITIES are, Highway, Rice, Row crop, Vineyard, NF, UTILITY, Industrial, OR agricultural ALL PURPOSE (Seems One of us, maybe ME, mentioned that one already...) . WHAT? NO mention of your CUT?
OK, let's let FORD tell us? Is it a CUT as you contend?
   / Baling with a compact - minimum size? #76
This is one of the most informative and entertaining thrreads going right now. I'm posting in order to not miss anymore posts. :D
I think, what is being said here, is you need to match your haying equipment to your tractor to your fields. What might work well for one person is not necessarily going to fit another's needs. Baling hay is part science, part art, part mechanical wizardy, and part luck. The type of grass, density, windrow size, moisture, and speed all play a part in what you need in a baler and tractor.
Just remember, if it was easy, everyone would be doing it.
   / Baling with a compact - minimum size? #77
I believe it was you that pointed out that the term "CUT" is realitively new to the tractor world. Nowadays we divide tractors up into categories based on more or less, size and HP... the real small lawnmower jobs are SCUT.. then move up into the 30's hp rang.. and you get CUT.. get higher into the 48+ or so range and you hit utility.. and then it gets even fuzzier where AG starts... .. maybee 80? One of the areas you see the breaking points are the lift category size.. IE.. cat 0, 1, 2, and 3. It's not a real stretch to call cat 0 tractors scut, cat 1, cut, and cat 2 utility.. etc.. etc..
Lets peer back to ford in 1965.. their smallest tractor was the 2000.. basically the same tractor as the 3000... move up and you got the 4000.. then the 5000.. etc.
The 3000 was a cat 1 tractor. While you could do lots with a 3000.. there is a big difference in being able to do something, and being able to do it well.. or doing it in an ideal situation. I contend that a 3000 does not compair to what we call a utility tractor today.. but rather to what we call a CUT.. both in weight and HP.
As a test.. i used my ford 850 on my 10' mower. I scooped up a concrete counterweight into the loader bucket as 'ballast'. My rear 3pt lift will groan, but get the mower lifted and resting on it's rear wheels in 'mowing' position.
The engine will spin up the 10' mower too.. just got to slip the clutch a bit. With all this empirical evidence .. I can say.. that yes.. my ford 850 will run a 10' mower in a flat pasture clipping bahial grass tops.. Is it ideal? Heck no.. it's crazy.. but it works. Big difference in 'possible' and ideal. Sure.. you can bail hay and pull a wagon with a 3000.. I've -seen- it done with a JD-B ( 28hp ) chugging can smoking and popping the whole way.. it the driver would have had a thermos of milk with him, the top inch of it would have churned to butter after 10 minutes... but it WORKED!
A 3000 is simply not what we are calling a utility class of tractor these days... If it had a cat 2 hitch, more hp, and a 4000 decal on it.. then yeah.. getting warmer there...
soundguy
   / Baling with a compact - minimum size? #78
Sully2 said:
Id have to be sitting there watching the scales to belive a 5030 with FEL and cab and even loaded tires goes 6500 lbs!!!! My buddy has an OLD Ford..I think its a "601 PowerMaster"..? ( automatic tranny thingy) and it doesnt move around like the 5030 does with the sq baler and Im mighty sure it dont even get close to 6500 lbs ( no cab on the old Ford...just lots of old cast iron)
His other tractor is a late 80's International ( 80 HP turnbo charged job) but it dont have a cab and the "pansy" ( thats my nickname for him..lol) wants to ride in that AC....lol
Actually the old 601 and the L5030 are pretty close for weight:3255 lbs for my '55 Ford 860 (600/601 bigger sister), and 3745 lbs for my L5030HST both without cab, loaded tires or any front loader. I bought mine due to knowing the 860 could accomplish anything I wanted to do (don't know about the baler gig as I'm not interested). They are very close in overall dimensions/power/weight.
   / Baling with a compact - minimum size? #79
soundguy
So, let's get this straight. YOUR definition of a "utility tractor" would be it should be able to power a 10' rotary cutter?
(Can you say "Grasping at straws in a feeble attempt to make a weak arguenment w/ thesaurus in hand" ;))
   / Baling with a compact - minimum size? #80
I spent several thousand hours on a Ford 3000 over the years and I am sure it was as much or more a tractor as say a new JD 5103... no way I would compare it to a cut other than maybe physical size. that tractor pulled stumps, disc harrowed fields and rotary cut a whole lot of acres.
2005 John Deere 330CL (A55272)
2005 John Deere...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
PALLET TOTE OF MISC CATCH PANS & HEATER PARTS (A58374)
PALLET TOTE OF...
New Holland T2420 (A53317)
New Holland T2420...
HOG COOKER MTD ON S/A TRAILER (A58374)
HOG COOKER MTD ON...
