Bale Spear for L3400
/ Bale Spear for L3400 #1
Goog
WA
Kubota L3400
Has anyone purchased or made a bale spear for a L3400?
I have seen them on the 3pt. also. Any help would be appreciated. Brian
/ Bale Spear for L3400 #2
I've used pallet forks to move the few rotten mulch-type bales I've had around here. Do you have the LA463? If so, that bucket is not QA; if you find a spear for it, it'll have to go on the front of the bucket, and that's a really long moment arm for such a weight. A couple of the heavier bales I've moved have really made my tractor lean forward, and that's even with the heavy backhoe attached. I wouldn't consider lifting a round bale without the hoe on.
If you have a hoe or some other heavy counterweight for ballast, and you don't have many bales to move, I'd recommend clamp-on pallet forks. If you don't have the ballast and/or have a lot of bales to move, you probably should consider doing the 3-pt hitch spear.
Let us know what happens. /forums/images/graemlins/grin.gif
/ Bale Spear for L3400 #3
My wife was nice enough to run out and buy us a 3ph bale spear after I strained my back earlier this spring and couldn't chuck the square bales around for a week or so. We use it on our L2350, she got it at Orscheln's ( local farm supply chain here in the midwest ) for $99. I have used it on 6x5 round bales that I would guess were around 1500 pounds or so, it worked fine. Other than the L2350 grunting a bit trying to pick up that big a bale, of course. The 3ph was rated for 1650 pounds, I would guess I was picking up pretty close to that amount.
I just picked up a couple bales and they are in the truck. The farm I got them from thought they were about 700-800lbs. I think I will try to fabricate my own spear. I am not sure yet if I am going to continue to use the round bales. Kind of an experiment but I do need to get them out of my truck. Thanks, Brian
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
2016 Tradewinds TG45-UL 45kW Natural Gas Generator (A61572)
2016 Tradewinds...
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
