Baking Soda Blasting
/ Baking Soda Blasting #2
very cool idea, I will have to try that. thanks for the info and link Travelover
/ Baking Soda Blasting #3
They sell the same basic set up for sand blasting. It may want to pull more baking soda they you would want but you should be able to regulate the size of intake and control it. Then you could use it for light sand blasting also.
One point, sand needs to be dry for that style but for my little bit of sandblasting needs works good.
/ Baking Soda Blasting #4
That real cool, thanks for the tip
/ Baking Soda Blasting #5
I agree. that is too awesome for words - thanks!
/ Baking Soda Blasting #6
I suppose that you could squeeze the tube some to try to regulate media flow, just a thought
/ Baking Soda Blasting #7
That is a great tip. I'll also have to give it a try. Right now I simply use a small air brush type sandblaster. They cost around $10 and work really well for the small items I generally want to sandblast.
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2023 Case TV380 (A62177)
2023 Case TV380...
New/Unused Mini Skid Steer Mounting Plate (A61166)
New/Unused Mini...
207281 (A52708)
207281 (A52708)
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
CAT 140M Motor Grader (A64047)
CAT 140M Motor...
