JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,022
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
The pins are located on either end of the PTO driveline, under the safety shield. Pull the safety shield (using a 7/16" wrench, loosen the two screws holding the covers,) and you will see them going through the spline of the yoke. Just curious, was not familiar with Kubota grass catcher, and the pitfalls of their ownership, and purchased an older model unit to use on my new tractor. For the record, I only use it in the sprint to pick up the dry thatched grass from first mow. Mine does not allow me to fill bags twice before breaking. FYI, mine uses 1/4" grade 8 bolts with a shoulder full length. I will begin tonight, to peen the threads of the bolt to guarantee the locknut does not loosen. Can you guess I also am having this very same problem, 9 years later!
I realize this is an OLD thread with 3 recent posts. I went back and read most of the posts. This whole thing baffles me as to how so many pins are being sheared.
-- The pin I am talking about is the one going through the U-joint half that mounts directly on the input shaft to the bagger. No other pin has ever sheared on mine.
-- I have had mine 14 years. Model GK60BX. Expensive, heavy and worth it's weight in gold for the leaves we have to handle here. Running on a BX2200.
-- In 14 years I had the shear pin go ONCE and that was when the fool operator knew the impeller was plugged and threw the PTO into gear.
-- OK,TWICE because the cheap off the shelf 1/4" bolt I stuck in there lasted one day.
The part is listed in the manual is シ-20 x 1 ス but that is a strange small round-headed bolt that recesses into the U-joint clevis body and has an Allen key head hole. That u-joint hole is also threaded on one side and larger on the other side to accommodate that round headed bolt. The threads in the clevis are slightly larger than シ in size. My guess is that the original intent was to use a special bolt just over シ diameter that would thread into the u-joint body rather than have a nut on it. The part number listed is 70050-04158 for the shear bolt.
-- Once I put in a new Kubota shear bolt (which costs $6.19 !! in 2016 $) it has never sheared again and never been a problem.
My GK60BX bagger has been used heavily for 14 years, does not eat shear pins, I do not picture any belts being inside that housing -- I'd be very shocked if there are as it surely seems to be just a geared unit.
I have to think that those talking about replacing 10 or 15 shear bolts are either using hardware store bolts that do not really fit right and not the factory replacement shear bolt. Otherwise, they must have something seriously wrong with the bagger --- binding, plugged up with something, worn out larger than normal holes through the shaft or some cause they have not fixed.
