Bagger search
/ Bagger search #1
WSaint
Virginia, USA
Cub Cadet 1220
I have a Cub Cadet 1220 with a 38" deck. Wonderful tractor, but I would like to add a bagger to it. I have been searching many dealers, auction sites, including EBay and others and have had no success. Any ideas on where to find one? Thanks!
/ Bagger search #2
pretty sure i can get you one. Where are you located?
/ Bagger search
I am located in the Fredericksburg, Virginia area. I don't mind driving some distance to get one. Thank you!
/ Bagger search #4
Ok heres the deal, try to follow me on this.
You have to order a 305 bagger which fits the 2000 series 38" & 44" decks. Then you have to order part numbers 703-1400 and 703-1401 which are the mounting brackets that will work with you mower. The brackets that come with the 305 bagger you can just toss. Ill order it for you if you want, but your local Cub dealer get this stuff.
/ Bagger search
Thanks alot! I will give it a try with the local Cub dealer. If I run into problems, I will contact you. Thank you very much!
/ Bagger search
I have contacted our local CC dealer. I explained the situation to them relative to the parts needed to mount the 305/2000 series bagger on the 1220. They looked up the part numbers 703-1400 and 703-1401 and said that it did not appear that they were available anymore.
Are they in fact discontinued parts or can I still get them?
/ Bagger search #7
Well they are available, not sure what you dealer is doing and why he can't seem to find these brackets. These numbers to sub, which a lot of cub numbers do so your dealer should be on the lookout for subbing numbers.
Anyway the part numbers are as follows,
703-1400A-0637 (LH bracket)
703-1401A-0637 (RH bracket)
There is no excuse as to why your dealer wouldn't be able to get these for you. If he can't I will be glad to get them and the bagger for you and ship them to you. Let me know if I can help anymore.
/ Bagger search
Thanks so much for your help. I will put a little more pressure on.
/ Bagger search #9
Just checked with CC. They have them both in stock. The LH retails for $18.10 and the RH retails for $19.69. I don't know why he wouldn't want to order them fo you. You even did all the work finding the part numbers for him. /forums/images/graemlins/confused.gif
/ Bagger search
I got my parts! Thank you for your assistance!
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
Hesston 3717 Hay Tetter (A65640)
Hesston 3717 Hay...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
