bagger for ballast?
   / bagger for ballast? #1
stevess
can a 3 bucket bagger offer enough weight on the back of a riding lawnmower with snowblower? i was thinking of adding a few bags of sand. anyone use this type of setup for snow removal? my ride is an older 13hp ariens with a 36" sno.
thanks
steve
   / bagger for ballast? #2
I would not use the bagger simply
because the bagger will not handle
the weight and it will tear and
become useless.
You will be further ahead having
the tires loaded with windshield
washer fluid to aid in your snow
removal as you will have much
more traction with some wind
shield washer fluid in the rears.
   / bagger for ballast? #3
I am thinking of using my bagger also. It has three plastic bins. I estimate that each bin will hold 50+ lbs without damaging anything on the bin or tractor mounting bracket. I also bought wheel weights and have chains. Will probably put fluid in the tires also as I need more traction when in reverse. By the way I also weigh 220 lbs. Maybe you should eat more????:laughing:
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
