Baffled
/ Baffled #1
stillstuck
1963 case 530 CK backhoe
I purchased a 1963 case 530 CK. ALL HYDRAULICS SEEM TO WORK QUITE WELL. I went to service it and the hydraulic filter housing (right side,4 bolt ,in front of battery) is dry. not even a film of oil. This does not seem possible I ran a camera in there and everything looks clean. I
do not know where to look next.Has anyone else seen this? I am at a loss. Thanks for your help, Dave
/ Baffled #2
Might have a by-pass valve? And it is in the by-pass (of the filter) position? No idea. Just help on your pondering. Do you have, or can you trace out a circuit diagram?
/ Baffled
I have an operators manual but that is all. It is a torque converter model by the way
/ Baffled
I believe the bypass is supposed to be a spring on the outside of the filter but mine does not have that and the filter does not leave room for one
2018 KUBOTA SVL95-2S SKID STEER (A65053)
2018 KUBOTA...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
2016 Isuzu NPR 20ft Box Truck (A64556)
2016 Isuzu NPR...
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
213137 (A64276)
213137 (A64276)
1062 (A63291)
1062 (A63291)
