Bad water pump?
   / Bad water pump? #1
cliff_890
John Deere 650 compact
Last time operating tractor while running it started smoking, I immediately cut it off. The belt was smoking. later, I cranked up the tractor it was running smoothly and then heard and noticed the fan blade was moving back and forth. The blade was hitting the radiator fan guard. Would that be the pulley attached to the blade or a more serious problem the water pump has gone bad?
   / Bad water pump? #2
Try moving the fan blades around, if they wobble the bearings in water ever it is bolted to have gone bad or the fan mounting bolts have worked loose.
   / Bad water pump? #3
With the fan belt off try rotating the fan. Check for smoothness and ease of rotation. Try spinning the pulley on your alternator as well. You'll soon determine which is loose or hanging up.
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2011 Ford Crown Victoria Passenger Car (A51694)
2011 Ford Crown...
Cat DPL40 Forklift (NOT RUNNING) (A50774)
Cat DPL40 Forklift...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
