Bad switch
/ Bad switch #1
Kdc72
Oliver/Row Crop88
I have an old Oliver Row Crop 88 that someone modified so that you set facing the rear and a snowblower is mounted on the 3-point. It works great for my snowblowing needs. But I went to start it this week to do some maintenance work on it and it wouldn't start. After a lot of troubleshooting, I discovered that the switch that turns the power on wasn't working. I am including a picture of the switch in hopes that someone can help me find a replacement. I would like to find an exact replacement if possible. I have tried searching on the Internet but have been unsuccessful so far.View attachment 4041764
/ Bad switch
Kdc72,​
Welcome to TBN, The attachment can not be viewed. I think that you have to have more post in order to post a photo.
So, you are saying that you have to submit a certain # of posts before you are allowed to put an attachment on? That doesn't make much sense to me…
/ Bad switch #4
I believe the minimum post requirement was put in a few years ago to combat link spamming. I believe the post count was set at 5 if I remember correctly.
/ Bad switch
So I have to make 5 posts like the one that I made before I can use attachments or does something like this response to you count as 1?
/ Bad switch #6
I believe that your response counts as an additional post so just keep on plugging away.
/ Bad switch #7
I remember farming with some old Oliver tractors including an 88 about 50 years ago. We never had any problems with the switches. I wonder if you might have some wiring issues going to the switch. They are pretty simple compared to the newer tractors.
/ Bad switch #8
It would be interesting to see a picture of your tractor. How did they modify the steering and the throttle? How do you shift gears while facing backwards? Our 88 didn't even have a three point hitch.
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
John Deere 620 Quick Attach Loader with Bucket (A65640)
John Deere 620...
100 Gal Oil Container (A64127)
100 Gal Oil...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
