Bad smell in house
   / Bad smell in house #21
put some veggy oil in the drains.... if like us you're away for several weeks the water in the drains will evaporate out and the septic gas will come in -- putting oil on top of the water keeps it from doing that.
   / Bad smell in house #22
another possablity is vermin dead or alive
   / Bad smell in house #23
we really need smell-o-web for these kinds of threads...
because lets face it
1) a dead critter has a very distinct smell
2) propane or NG has a very distinct smell different from 1)
3) sewer gas has a very distinct smell different from 1) or 2)
but its like trying to describe colors... just how do you describe a smell?
   / Bad smell in house #24
Excellent idea.
   / Bad smell in house #25
Won't the vegetable oil turn rancid, and then....STINK?
   / Bad smell in house #27
Jon, I have a small chest-of-drawers that I bought unpainted many years ago. I stained and finished the chest myself. Problem is, it stinks. It's not a strong odor, but when you close up a room with it in it, the odor of the wood or the finish is very evident when you enter the room. With a 2-yr old house, you could still have paint, adhesives, or putty causing the odor. I doubt it is propane.
For the record did you stain/finish the inside of the drawers? A no-no, that smell will never go away.
For this, turn the gas off and vent it out of the pipe as best you can before you go. Crack a window if you can. If its still threre...Get an airwick, scented candles, poporie, and a gallon size of Frebreeze!! :D
   / Bad smell in house #28
doesn't seem to .....maybe cause it mixes with the water? dunno .... pinesol works too --- but I'm afraid of it hurting the septic.
   / Bad smell in house #29
do a high pressure test of your propane lines: i usually air gas lines to at least 80+ psi and make sure it will hold for a day or two with absolutely no drop: then your assured you don't have a leak...
heehaw
Make sure you don't put such high pressure on any appliance as it will blow them,
For the record did you stain/finish the inside of the drawers? A no-no, that smell will never go away.[
No recent finishing in the house or drawers. No way its a critter
2016 Ford E-350 Enclosed Service Transit Van (A50323)
2016 Ford E-350...
Diesel Forklift (A51691)
Diesel Forklift...
Massey Ferguson 65 Tractor (AS IS) (A50774)
Massey Ferguson 65...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
John Deere 648R (A50121)
John Deere 648R...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
