Bad news big repair
/ Bad news big repair #141
Thus maybe a little simple but I would go to the parts store and get a glow plug controller relay for a 87 6.9 ford diesel and install it to the glow plugs that way it’s automatic with the switch and your not over heating them
/ Bad news big repair #142
What an interesting thread.
Lots of good suggestions and a bit of frustration to keep things percolating.
I sure hope the ecu is not the problem. If it is, and direct wiring the GPs is not workable, there are not many options. A block heater seems a cheap fix even if you need to run power to where the tractor is stored.
Wonder if this will be like the oil drain plug thread?
/ Bad news big repair #143
I apologize if I missed it, but I did not see any comment about how cold the ambient temp was when you tried the system. Kubota uses a pretty low ambient temp to activate the glow plugs, somewhere around zero degrees F on my L4060 if I remember correctly. And the indicator for the glow plug activation is very easy to miss.
/ Bad news big repair #146
I find it hard to believe that if you used a relay capable of 100 amp and a push button directly to the relay and the relay directly to the glow plugs, with the other wires unhooked that the tractor would know the difference. You cant screw it up with a push button. Mine has 3 glows and they draw 45 amps, If you have 4 of course it will take more current.
/ Bad news big repair #148
Purchased my M135X in warmer months almost 3 years ago (April 2019). Never thought to see if the glow plugs worked. They actually won’t work if it’s over 41*.
Last winter, I realized the glow plugs weren’t working. Ohmed out wires, looked at wiring for mice damage, water damage, bad grounds, etc. Ohmed out wiring. Thats when I learned the glow plug system in larger kubotas is more complex than I thought. All 4 glow plugs passed electrical testing.
The glow plugs have 2 sensors one for air temp, one for water temp. The ignition switch is also part of the circuit. Then there are 2 relays and a fuse. All of this is controlled by the ECU. Last winter, I replaced
Key switch
water temp sensor
air temp sensor
both relays
fuse
Still no glow plugs. With nothing left to replace or test, I succumbed to a very reputable Kubota dealer. They basically did all the same things I did and replaced one of the new sensors I had already placed.
Still nothing. They called Kubotas double secret probation hotline and Kubota thinks it’s the ECU.
ECU price $6000 :(
ECU Not returnable and no guarantee it will fix glow plugs.
So I’m out of answers. Any thoughts on other possible avenues to pursue?
Wow! Well I will never buy a Kubota!Thanks for the info
/ Bad news big repair #149
Ford truck starter relay $10.00. Will work great.
/ Bad news big repair #150
The M135X was produced between 2009 and 2014, accordingly to TractorData. Definitely not a 3 year old tractor.
Big companies really have special funds for so called "good client", who bought more than one product, was/is loyal in after sales programs, recommended the brand name to the other clients...
Sometimes it works if the machine gets expensive failure even after more than 3 years.
/ Bad news big repair #151
The ECU reads the air and water temp sensors and they are both part of the glow plug wiring circuit and it has been stated that if the relays are bypassed, the tractor derates itself.
So how do you bypass all that and “simply install a switch”?
If you measured the resistance of a glow plug, and flipped the glow plug hot wire to a resistor with the same value, you can probably trick the ECU into thinking that the glow plug is still in circuit and the wiring for all of the relays is intact. Then you're able to control the glow plug with your own switch through a new supply wire, and the ECU has no way of telling that you're cheating, tho Kubota might deny warrantee service. It's *entirely* possible that the ECU is supposed to handle the glow plugs entirely on its own, and/or designed to NOT allow glow plugs above 41F. The former is the general move towards "improving the user experience" (gag) by removing as many buttons as possible. As to the latter, durn it, if there's a button, I *expect* the button to do what it's told unless it's going to kill me. Hitting the Park button at 70mph is something that I'd expect a car to refuse.
Your best bet to is to put in a direct query to your Kubota service guy as to whether your tractor model and year ECU is *supposed* to inhibit glow plugs above 41F. If they don't know or seem uncertain, get Kubota itself to answer that question.
/ Bad news big repair #152
In my (never to be) humble opinion, to have to perform and jump through all these hoops to get a tractor to run correctly, some engineer has gone way, way, way, beyond good engineering!
/ Bad news big repair #153
Would it be easier to install an engine block heater and forget glow plugs?
/ Bad news big repair #154
:ROFLMAO: The ECU does not care about the glow plugs obviously. The tractor is working now with the glow plugs disconnected because the relay is not Energized. The OP does not have to worry about fooling the ECU.
/ Bad news big repair #155
Goodwill claims are reserved for original owners.
/ Bad news big repair #156
Key switch
water temp sensor
air temp sensor
both relays
fuse
ECU price $6000 :(
Just a thought here but I have a frost plug style block heater in my M85 Mahindra. -10-15c [5-15F] plug it in.....wait for about 3 hours and the manifold heater does not even cycle. An awful lot of electricity can be bought for 6k. If that would work for what you use the tractor for in the winter it is both cost effective and IMO works just fine. As a matter of fact I would be surprised if you could not get all you need from Kubota.
/ Bad news big repair #157
I've seen Hay Dude owns more than one Kubota product. But don't know if he is original owner of all that equipment or not.
/ Bad news big repair #158
Well the last M135 was built in 2014 and he said he bought the tractor 3 years ago. I'll go out on a limb and say he's not the original owner of this tractor. Whatever else he owns is irrelevant.
/ Bad news big repair #160
Maybe. Just sales date (especially in tractor business) could be way later, than production date.
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
1062 (A63291)
1062 (A63291)
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
