Bad Habit?
   / Bad Habit? #1
DanielVT
Southeastern Vermont
Kubota L4400DT
Was wondering about this - when I'm cutting something up, I have a habit of swinging the saw away from the work with my left hand if I need to use my right hand to pull something out of the way, reposition what I'm cutting, whatever.
When I do that I pop the chain brake on with the back of my left hand, so that I don't make any stupid mistakes like cutting off a leg or something. I don't like to put the saw down, and I really don't like shutting it off and putting it down.
Is using the brake like that a bad thing to do? Will constant use wear it out so that in a real emergency it doesn't function properly?
   / Bad Habit? #3
Chain break cheaper than limping the rest of ones life. ;)
Not very often w/one hand object can be set for safe cutting.
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2002 Kendall 12ft Enclosed T/A Trailer (A50324)
2002 Kendall 12ft...
1995 Case IH 2144 Combine (A50514)
1995 Case IH 2144...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
Howse 10' 3pt Rotary Mower (A50774)
Howse 10' 3pt...
