Bad Day at Block Rock - errrr - Make it Bad Year.
   / Bad Day at Block Rock - errrr - Make it Bad Year.
Last few mornings the sunrise has sure been pretty. Use to have a picture of 1 where it looked like the sky was on fire.
No craps this AM or last night. Found & took some potassium pills. Think they are working. Didn't walk quite as much yesterday as I have been.
Reason: When things start going wrong, they just don't stop.
First problem, router would not give up its bit. That's after finding a wrench that fits. Get it changed & make my new & improved window frame top. A good plan that will not work, give it another shot, still wrong. Quit playing with it for the day.
Doug out an old goose neck lamp, clean it up & mount it to light the flag. Works, but can not be adjusted up enough to light the rifle. have some canned lights that will work, may put 1 up today.
Did a lot of piddly little things, pick up nails & put in jar, other things like that that don't amount too much.
Time to go out & watch the world go by.
More later,
Jim
   / Bad Day at Block Rock - errrr - Make it Bad Year. #852
More later,
Jim
Well, no craps is a good thing but I will assume you meant cramps!! Keep the stories coming, enjoying them very much.
   / Bad Day at Block Rock - errrr - Make it Bad Year. #853
A Back,
It is just French's Mustard. I keep two bottles in the ice box. One for me and cramps and one for condiments. I also keep a bottle in the hangar's ice box.
hugs, Brandi
Your French's mustard does contain turmeric, but it also contains, "natural flavor", a pseudonym for, MSG, which is not needed in your mustard or any other food. You will find MSG in most catsup, too.
   / Bad Day at Block Rock - errrr - Make it Bad Year. #854
Another item that will cause cramps is no enough water. There is a rumor that it is easy to get dehydrated in Crash's neck of the woods. :D
   / Bad Day at Block Rock - errrr - Make it Bad Year. #855
I had one like that. After loosening the nut, you had to tap the bit deeper with a wood block to make it release.
Bruce
   / Bad Day at Block Rock - errrr - Make it Bad Year. #856
I am trying to figure this out :D. I use my tongue to lick. How do you do this again?
I know the hot stuff at the chinese places I don't let get on the roof of my mouth.
Lick is the wrong word. I pull it off the spoon with my upper lip. You gotta figure out your own technique. I gather you won't be able to do it my way.:rolleyes:
hugs, Brandi
   / Bad Day at Block Rock - errrr - Make it Bad Year. #857
.....but, but, but, I like MSG.:rolleyes: Why would I want to find it in catsup?:confused3:
hugs, Brandi
   / Bad Day at Block Rock - errrr - Make it Bad Year. #858
What about trying the 'Hot English Mustard' That'll realty blow your socks (sox) off.
   / Bad Day at Block Rock - errrr - Make it Bad Year. #859
Here is a fascinating article on mustard. How mustard is made - manufacture, making, history, used, processing, product, machine, Raw Materials
Just one example: An 8 oz (226.8 g) jar of mustard requires approximately 1,000 seeds. (by the way, did you know you only have to have faith equal to the size of a mustard seed. Jesus said: Truly I tell you, if you have faith as small as a mustard seed, you can say to this mountain, 'Move from here to there,' and it will move. Nothing will be impossible for you."
Good morning,
speaking of mustard, I like the plain old Frenches. Something different to try ( I like it ) add a little mustard to your Mayo, a whole new taste. great for French fries. Didn't eat catsup for years because of 29% sugar. Kind of like it & use a little now & then. Never liked radishes, they burned my mouth ( Chile was fine different burn.) + taster.
Would have got a lot more done yesterday were it not for dumb, stupid mistakes. Just little things, but enough to make the pope cuss. :D
Worse & really scary. The flapper valve in the back of my neck closed up & I could barely breath. Makes you think you are going to die & afraid you won't. Cough, gag, & some pain. Took over an hour for it to mostly go away. A little irritating for another hour or so.
Going to run out of lumber soon, would last a little longer with out the mistakes. The way things are going I would not even qualify as a rough carpenter, more of a wood butcher.
This AM would be perfect for sitting out, were the deck closed up & I had the propane heater working. 52 & dropping. 10 Degrees lower than yesterday. Yesterday was a real good day for getting things done, fairly cool most of the day.
Some times wonder if the pain clouds my judgement & adds to some of the dumb mistakes???
Picked up a few things yesterday & got them off the deck. Right from the start I should have cleared everything off the deck, but didn't. Figured out that I need some shelves out there, will get or make some brackets, keep most things off the table.
Folks don't seem as happy as they use to. State of union or???? I try to make people smile when ever possible. Readers Digest many years ago said, Give everyone a smile, it's the cheapest thing you can give away and still have more + plus ut may come back to you.
Soon the election will be history, all over but the shouting. When in business I hated elections, sure seamed to hurt business.
More later,
jim
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
