Bad battery ???
   / Bad battery ??? #1
G3033H
Bronze Member
Elma, NY
LS G3033H
Hey all have a really weird problem, I got the tractor started and working today for about an hr. then brother in law stopped by so I shut down restarted ran for another 30 min. And the tractor died, no dash lights no nothing, pulled the battery cleaned the terminals and it won't charge ! Checked charger that's working, after 3-4 hrs on a 20 amp charge I would think it would have some kind of charge but nothing ! It's only 5 mths old The tractor since I got it and 81 hrs. Any thoughts ???
   / Bad battery ??? #2
check voltage on bat and report back.
   / Bad battery ???
It is "0" no volts no amps right now I have it on charge at 5-6 amps
   / Bad battery ??? #4
   / Bad battery ???
Hey Murphy1244, it is at "0" volts
   / Bad battery ??? #6
Your battery is fried, sorry but you must check your main ground wire before you install a new one.
   / Bad battery ???
The ground was is ok the tractor is only 5 months old, this should be under a warranty I would think, I tried to jump it with the truck and got power to go thru the tractor but not enough to crank the engine to start it
   / Bad battery ??? #8
You have a major short or a no ground problem. If under warranty take it in. Sorry.
Murph
   / Bad battery ???
Thanks Murph
   / Bad battery ??? #10
No problem my man.
Murph out
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
UNUSED FUTURE MINI SKID STEER MIXING BUCKET (A51244)
UNUSED FUTURE MINI...
Wolverine Quick Attach Tree Spade (A50514)
Wolverine Quick...
