Bad alternator?
/ Bad alternator? #1
cjw
Winchester, VA
MAHINDRA 3510
I replaced the battery. The alternator is not charging. There are two other wires that come off of the battery and head back to the control panel. There is a 3 mile amps draw off the battery. I can not find my manual to see a wiring schematics. Can some one please post the wiring diagram?
Thanks!
Chad
/ Bad alternator? #2
What model tractor do you have? The problem may just be a blown bulb. On some models, if the charging lamp bulb is blown, the alternator will not charge.
/ Bad alternator?
It is a 3510. What is a charging lamp bulb? There is a little wire that is coming off the positive side that is drawing 3 milliamps but I have no idea what it goes to. The tractor runs fine without the little wire but does anyone know what it goes to.
/ Bad alternator?
Here is a picture of the wire I am talking about.
Chad
/ Bad alternator? #5
According to my wiring diagram, it goes through a fusible link and then to the glow plug relay.
The glow plug relay has four wires.
black/yellow: from the battery
black: to ground
black/white: to glow plugs
black/red: to the glow plug timer
The black/yellow from the battery changes to a black/red when it passes through the connector to the fusible link. It then changes back to a black/yellow from the fusible link to the glow plug relay.
Hope this helps.
Joe
/ Bad alternator? #6
The charging lamp bulb (idiot light on the dash) thing doesn't apply to the 3510. There may be a definate possibility that one of the fusible links that GIJOE mentioned is bad. I have not run into this problem on a 3510 but I do remember something at one of the service schools about the fusible links. All I can remember right now is they are under the hood one I think down by the starter and I think one by the right side of the radiator. I believe it is a 2 wire plug with just a loop of fusable link wire. I will check tommorrow on the 4110 on the lot to see how my memory is. I'll be back in touch tommorrow.
/ Bad alternator? #7
If the fusible link is bad that would prevent any amperage draw on the battery. At just 3ma I'm thinking the glow plug relay may be bad (energized). I may be wrong, but worth looking into.
Joe
/ Bad alternator?
Joe, you are right. It is the fusible link! I pulled the fuse & it is bad. There is no continuity between the fuse posts.
Thanks for all the help.
Chad
/ Bad alternator?
So I have had my tractor running all summer without using the glow plug & haven't gotten around to replacing the bad fuse. Still can't find the owner's manual either. The fuse is yellow with nothing written on it. Does anyone know what watt it is? It is getting cold & the tractor is hard to start on the cold mornings. I am hoping to pick up a fuse tomorrow, but not sure which one to get.
Thanks,
Chad.
/ Bad alternator? #10
CJW,
Since after the hurricane, I don't get home till after dark, so I can't physically check to see what's in my tractor. According to my service manual, the glow plug relay is a 5 amp fuse, but it doesn't say what color it is. Most fuses are color coded. If you can find the right type of fuse then the same color will be the same rating. Hope this helps.
Joe
/ Bad alternator? #11
CJW,
I finally got a day off and was able to look under the hood of my tractor. The glow plug relay is a yellow 15A fuse. I also found my owners manual, and it also shows it to be a 15A fuse. I double checked the service manual to make sure I didn't read it wrong and it shows a 5A, so, I guess there is a misprint in the service manual. I hope the previous post didn't cause you any problems.
Joe
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2025 JMR Tree Boom Mini Skid Steer Attachment (A66734)
2025 JMR Tree Boom...
More info coming soon. (A64557)
More info coming...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65054)
2023 WALLACE-THE...
3098 (A63117)
3098 (A63117)
