Backup camera on tractor
/ Backup camera on tractor #1
ernemats
Veteran Member
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Has anyone put a backup camera on their tractor, if so how does it work. I have thought about it as I have problems with turning around to see what is behind me and if I am doing what I want to do. I have a neck problem and it is hard to see when using a back blade for example.
/ Backup camera on tractor #2
Get a minimum 7" screen wireless camera system off amazon for under $200. I wish I got the 9" screen and two cameras, I can't find extra cameras compatible with my 7" 4-channel 1 camera system.
/ Backup camera on tractor #3
I have one mounted on the cab, so I only have it in the winter when the cab is on. The biggest challenge is the mounting of the camera and screen since tractors don't have a lot of convenient places. Maybe on the ROPS and top of the dash? Wiring is easy. I just have a switch on the hot wire so I can manually turn it on. Bigger is always better. I think they all work OK but higher quality will cost a little more.
/ Backup camera on tractor #4
I have 3. One facing left, one facing right and one in the center, above the 3PH and they all feed a large split screen monitor.
/ Backup camera on tractor #5
If you don't have a cab, I'd wonder about the monitor screen being washed out by the sun pretty often. I've got a bad neck too, and no cab- holding out for something like a practical version of Google Glasses that would be cheap enough to try.
/ Backup camera on tractor #7
I have 2 backup cameras on the Skid Steer, the BC 773 machine is notorious for poor visibility. The 7" screen is mounted to the roof. The 2 cameras have different field of view characteristics. 1 is normal mounted just below the roof. The other is a wide angle mounted on the engine hood. The camera comes on with the key switch and I switch between cameras with a toggle switch next to the key.
All from Amazon and pretty easy to hook up. Been working flawlessly for about 1 yr. I wrote it up with part numbers in the SS section.
/ Backup camera on tractor #8
Remember "wireless" means they transmit wirelessly;you still have to power the screen and camera.
Purchased a decent one;find it about useless,washes out in the sun(cab tractor).
/ Backup camera on tractor #10
Just a word of caution. I have a backup camera (factory mounted) on my Power Wagon. The "eye" is incorporated into the tailgate handle. You view the results on the dash screen.
About a year ago I backed the Power Wagon right into a vertical sheet of plywood. This plywood is the base for my fuse panel and is mounted on the last power pole. Put a nice vertical crease in the tailgate. Of course - no damage to the plywood or fuse box. Probably would have helped if I removed the frost accumulation on the "eye".
I was pretty sure of where I was backing - up until I hit the plywood. In retrospect - that vertical sheet of plywood is difficult to see with the backup system on the Power Wagon. I've painted the plywood red - much easier to see now.
The cost to replace the tailgate - $2500. I was shocked. Because of all the curvature in modern tailgates - they are replaced - not repaired. Live and learn.........
The main problem I see is my tractor does not have a cab or even roof to protect the screen from the elements
/ Backup camera on tractor #12
I installed a cheap 2 camera wired system on my cabbed tractor a few years ago. It works well, and the 7" screen is clear under almost all lighting conditions. I went with the wired system because everything gets powered through one connection from the screen, so I just made one power connection at the screen and ran the video cables to the camera positions.
/ Backup camera on tractor #13
I guess you could use a cover for the monitor when it is not in use.
It might be time to think about a roof?
/ Backup camera on tractor #14
I use a portable camera system powered by cordless tool batteries with magnets to mount the cameras. There is no wiring or mounting headaches to deal with and the cameras can be placed anywhere. The system is easily removed so using it on an open station tractor is no problem.
The cameras can be placed on the tractor, the implement or even on the ground to get the best viewing angle.
Here's a link to an old thread on how I made the system:
Portable Tractor Camera System
2022 MACK ANTHEM AN64T 6X4 T/A  SLEEPER TRUCK TRACTOR (A59906)
2022 MACK ANTHEM...
Sellick S80 (A60462)
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
