Backing out rusted up Torx bolts ??????
   / Backing out rusted up Torx bolts ?????? #1
kebo
Elite Member
Lexington, SC
2001 John Deere 790 4x4, bar tires
I had a thread sometime ago about repainting my 16ft trailer that I use to haul my tractor on. My plan was to pull the deck boards off and take it to a guy who paints them on the side. He was going to sandblast, prime, and paint it for about $400. After that, I was going to put new deck boards back on.
So, last weekend I went to Lowes to start the process. I bought 15 pieces of PT 2x6x16, which is what's on the deck now, total came to $140 bucks. This evening I took a hard look at getting the old boards off. Wish I had done that last week!! I might be changing my direction if I had. The boards are held in place with #27 TORX screws. They staggered them on opposite sides from end to end (of the boards). Not every board has the same number of screws drilled into the angle joists. Some have 4, some have 5, & some have 6. (NOTE: The ends of the 16' boards are tucked under a 2" wide metal strip). I tried backing out a few screws with a #27 bit in my Dewalt 18v drill and it would not even budge the first one. :( They are all rusted solid. Looking at the bottom, there is about 1" of screw sticking through the bottom of the angle iron, all of it nice and rusty too. I guess they are 3" long screws. Most of the screws you can't even get the TORX bit into the screw because of dirt, rust, and corrosion. I did find a few screws that were broken off.
I had hoped to reuse these boards on a foot bridge across the creek at my hunt club, but that's looking pretty doubtful now. I'm thinking I will pretty much have to destroy these boards with a combination of pry bars and sawzall to get them off.
I'm also thinking now that I could have probably sold this trailer for $800 (which is what I paid for it 10 years ago), add about $500-700 to that and buy one already looking much nicer. You think Lowes will take the lumber back? :eek: I see trailers on CL all the time in that price range, but I really like this trailer. It has a sturdy drive on ramp with spring loaded assist, tongue jack, 12" high sides filled in with expanded metal, and brakes on one axle. The trailer nameplate indicates it was made in '98 though.
Any thoughts on the best way to get the screws out,and maybe salvage some of the boards??
   / Backing out rusted up Torx bolts ?????? #2
Good luck saving the boards.
Every time I've redecked a trailer I ended up using a cutting torch to cut the heads off the screws, pry off boards. Take a hammer and bust off what is left of the deck screws. Install new boards. Drill new holes and install new deck screws.
   / Backing out rusted up Torx bolts ?????? #3
Put a floor jack under your trailer. You may need to put some blocks of wood on your jack depending on how high your trailer is. Jack up the trailer by the boards so that the screws pull through the board as you jack up on the board. After jacking up all the boards causing them to pull away from the frame of the trailer, cut off all the screws with a cut of wheel or break them off with a pair vise grips by bending them back and forth a couple times. Don't bother trying to remove the old ones. Just use new self tapping screws for the new boards. Good luck. This project is not the kind I call fun:).
   / Backing out rusted up Torx bolts ?????? #4
I second using a cut off wheel to cut the screws so you can get the deck boards off. The last one I did I flipped the trailer over onto its top and it was much easier to work on from there. Did all of my cutting and then flipped it back over and popped the boards off and drove the screw back out of the boards. It worked for me.
   / Backing out rusted up Torx bolts ?????? #5
I'm third on the cut off tool the screws are hardened and are really hard to drill you might try and drill heads off and jack boards up off them.
tom
   / Backing out rusted up Torx bolts ?????? #6
I agree with the others, even if you could get the old screws out, how likely is it that you can drill holes in the new boards in just the right spot?
Some good idea's I hadn't thought of!! I knew I came to the right place to ask! :D
The cutoff saw will definitely do the trick. Can I get a 4.5" blade that will fit my angle grinder and use that to cut/grind off the screw heads?? If so, what kind of blade would work the best for this??
I think if I can get the screw heads off, the boards will pry up pretty easily. I may have to cut about 1" off of one end of each board (where it's tucked under the metal lip) before I can start prying on them.
I think that as bad a shape as these boards are in, the screws will pull right through the boards with a good prybar, or by using a jack underneath the boards like Matt suggested. That will probably do the least damage to the boards, but will probably be a time consuming deal.
I really had hoped to re-use those existing holes in the angle joists but it will probably be easiest just to break them off (after I get the boards off) and re-drill new holes like DK35vince suggested. After I get the boards off, and break the top portion of the screws off, I might be able to use a visegrip wrench and clamp down on the screws on the bottom side and screw them on through the bottom. Will try one to see if that works or not.
Thanks for the suggestions!!
   / Backing out rusted up Torx bolts ?????? #8
I had the same problem with a shipping container, only with phillips-head self tapping bolts that were so hard they stripped the impact driver phillips inserts (I was using the manual impact driver with a hammer at first). Also, the shipping container floor is 1 inch thick on channel, so no pulling up the deck with a pry bar. With a little info from an aircraft mechanic, I learned the following method which works.
First, use spray Aero Kroil, or just the plain Kroil, (orange can - hardware store or gun store) to dissolve the rust and crud on the bolts. It works much better than penetrating oils. Let it sit for a while, maybe even a day. Then if you have access to a small air-impact (1/4th drive) butterfly driver, use it with your torks drive and you will be amazed at how easily the bolts/screws come loose. The vibration and Kroil make it mostly effortless, and most of the threads were reuse-able. If your situation was like mine, it might be difficult to cut all the bolts, but you can easily spray them.
   / Backing out rusted up Torx bolts ?????? #9
If you really want to use those holes put the boards in place drill up through hole from underneath and put carriage bolts in.
I think you will have a heck of a time getting them out drilling or spinning them some how.
You might try cut and pry routine and weld a nut on them and spin them out with the nut.
tom
   / Backing out rusted up Torx bolts ?????? #10
Angle grinder with small cutting disks and cut flush.
The heat from cutting will help loosen the self tapping screws and a good whack with a 3 pound ball peen will also help loosen them up.
Also some sprayed on lube (WD40 or such).
You would then probably be able to back off the screws.
A good quality torx bit and an impact type drill should do the trick.
Another thought might be to tap with light blows a spare torx bit into the drive hole to kinda clean it up before attempting to unscrew the fasteners.
Good luck, I don't envy U the job.
PS; I re decked my trailer last year, so I know the chore!
(used same holes drilling from below and 1/4" carriage bolts and pneumatic driver to tighten them snug,I now plan to re-treat the wood annually as I do not wish to repeat the chore.)
   / Backing out rusted up Torx bolts ?????? #11
You may be able to avoid the cut off wheel and pry bar ordeal by simply drilling out the torx head and entire screw with a sturdy 1/2 drill. With a bit stop on the drill so you avoid damage to the steel portion of your trailer. Wooden boards will just lift out with no prying or cutting.
   / Backing out rusted up Torx bolts ?????? #12
i did mine about 2 years ago. i put the torx (a good quality craftsman) on the screw head, tapped it a few times with a 3 lb hammer, 3/8 ratchet and a straight steady pull. everyone of them came off. while boards were off re-drilled all holes slightly larger than 1/4". when i put new boards on drilled up from the bottom through the wood and installed 1/4" carraige bolts, one in each board and each cross member. not a pleasant job but necessary. i used a good treated lumber 2 x 6 and hopefully never have to do it again, the carraige bolts will have to be cut off.
   / Backing out rusted up Torx bolts ?????? #13
Ah, those lovely Torx self tapping screws!
My trailer was re decked last summer. I just cut the boards from the top and use a pry bar to break them off or pull them through rotten boards.
Ground the remaining stubs off with angle grinder.
When applying new decking used bolts. Placed the board and then drilled through board and support Chanel's. In some cases used pipe clamps to pull boards into alignment. :D
   / Backing out rusted up Torx bolts ?????? #14
All very good ideas for wooden deck removal. Last few trailer decks I have done, I did not redrill the cross metal beams to lock down the new deck. Just get fender washers that fit your bolts and drill the wood adjacent to the angle iron flange and clamp to the beam. Saves drilling time and more holes in the iron. You mentioned a 2" lip on the front. Your decking will not move and is held nicely with the fender washers as clamps. You can use more bolts too. Makes it easier if you should have to redo in the future.
PS-I also had to destroy the old deck on removal.
   / Backing out rusted up Torx bolts ?????? #15
In my experience, Lowes will take back virtually anything if it is not damaged and in resellable condition, you are polite, and have a reasonable story about why you need to return it. Actually, any one of the above will usually do it!
- Jay
   / Backing out rusted up Torx bolts ?????? #16
I've returned lots of items to lowes,as long as you have a receipt you should'nt have any hassles. russ
I've decided to go ahead with my project. I just like it enough to want to keep it. It's 22 yrs old, so whether I actually get it repainted or not, it needs to be redecked for certain. The boards are in pretty sad shape now. Two of them are broken in the middle of it, up near the front of the trailer. Somehow a mean ole nasty stump crawled up under it and pushed up a couple of crossmembers (angle joists) so this will give me a chance to try and beat the crossmembers down with a sledge hammer. Stopped by a hardware store today and picked up a couple of 4.5" cutoff discs, and a nice new 30" prybar. Wish me luck! :D
   / Backing out rusted up Torx bolts ?????? #18
If the screws are firmly rusted into the members...all you are going to need after the boards are pulled off is a hammer...there is a good chance all they will need is a wack or two with a little english and they should go flying...
Also there is a good chance if you smack sharply on the rusted up hole where the screw was there is a good chance that what is left of the screw shank and the rust flakes will jettison out after a couple of smart wacks...
   / Backing out rusted up Torx bolts ?????? #19
I'd take a different approach to removing the Torx bolts/screws. First wear goggles/ polycarbonate safety glasses for whatever you do on removing them; flying rusty screws is a real potential eye disaster in the making.
I would then have a few correct sized Torx drivers (that fit a 3/8" drive ratchet wrench) ready to sacrifice if needed. Then I would spray each and every one with Aero Kroil or similar and then whack each head with a hammer to loosen the bolt in the trailer subframe. After enough time to loosen up the rust try the Torx driver and a small breaker bar instead of a drill.
If this doesn't work then switch to a hole saw just slightly larger than the head of the screw and drill down to where the board meets subframe and remove each board after drilling out a core that encompasses the screw's head. No lifting, hopefully no prying, and possibly some cutting needed at the board ends where stuffed under the bracket. Once boards are removed then use cutoff tool and cut flush to deck. If wanted to reuse holes use a punch to set your hole site and prevent the drill's bit ability to roll off the remaining screw and drill out the hole. Then use self tapping ceramic coated Torx lags. Job completed for your lifetime, hopefully. :thumbsup:
Gold colored ceramic coated Torx lags are not cheap but they are terrific and you won't be breaking any of them from over torquing either.
   / Backing out rusted up Torx bolts ?????? #20
i have done many re-deckings of semi trailers. same concept, just a larger scale. there is no way some magic potion in a can is going to make those screws come out. i usually use an excavator with a thumb, and plunge the thumb through a deckboard and grab on to it.
209275 (A59823)
209275 (A59823)
New Holland 650 Hay Baler (A53317)
New Holland 650...
2020 Ram 3500 4x4 Ext. Cab Pickup Truck (A59230)
2020 Ram 3500 4x4...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
GIYI SGB20-20" HYD STUMP GRAB BUCKET (A60430)
GIYI SGB20-20" HYD...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
