Backhoe with no power
/ Backhoe with no power #1
grtcrowd
Kubota B2320
Greetings! I'm new here and a newbie to using a PTO pump. I purchased a LW-6A backhoe from Titan and have it connected to the tractor via a PTO pump. Hooked everything up but nothing happens. Checked specs for backhoe to pump and all are within specs. Where do I start? Thanks for any suggestions!
/ Backhoe with no power #2
enough hydraulic fluid in tank?
pump might be air locked, loosen discharge pump fitting to allow air to bleed out.
/ Backhoe with no power #3
Not sure what you have or have not checked, so this may sound ridiculous but first thing I'd check:
- The PTO is engaging on the tractor and turning the pump
- You have plenty of hydraulic fluid in the tank.
- The pump is turning in the proper direction.
So far so good on all mentioned items. Tried bleeding the lines but with the line disconnected we get fluid blowing out of the filler top. Hook it back up and that stops.
/ Backhoe with no power #5
You sure the pump is not on backwards? If you take a line off and try to bleed it but it blows fluid from the filler, that seems like its pumping backwards to me. Does anything come out of the disconnected line?
Arrow indicator on the pump itself is indicating the proper rotation. When the line is disconnected there is a flow, but not very strong.
Here's our setup.
/ Backhoe with no power #8
Hoses are not connected properly. The out from the pump should go to the Pressure port of the control valve. The line from the tank should go to IN on the pump.
Just disconnecting the hoses at the pump and rotating the pump so the body is down, reconnect the hoses and you're good to go.
By the way, pictures are indeed worth a thousands words.
/ Backhoe with no power #9
I believe PTSG has the correct response on lines being connected wrong. On a gear pump the oil flows around the out side of the gears from in to out.
Thanks so much for the help. We'll have to get a few more fittings then try it.
/ Backhoe with no power #11
The pump has the words "In" and "Out" written on the casting. So as @ptsg says, switch the hoses and it should work.
Well, after some modification at the tractor to flip the PTO pump, it is working. Still has a few bugs in it, but nothing we can't deal with! Thanks everyone for your comments and help!
/ Backhoe with no power #13
Thanks for the update.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2001 International 4000 DT 466E (A60462)
2001 International...
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
58in Padfoot Vibratory Roller Skid Steer Attachment (A61572)
58in Padfoot...
AUCTION STARTS HERE @ 9AM (A63291)
AUCTION STARTS...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
