Backhoe tooth replacement
/ Backhoe tooth replacement #1
telephoneman
Upstate New York
John Deere H,John Deere 650,John Deere x540,International 240 Utility
Neighbor was over to help with a tree removal with his JD4400. He lost a tooth and we have another. What is the procedure for peening the new one on? we've used several approaches and they don't seem to be working. Please, what's the trick? Any help will be appreciated.
/ Backhoe tooth replacement #2
I'm sure there are lots of variations of teeth and holders. Mine have the concave depressions in each side of the tooth holder. I heat the spot (red hot) to peen and then use a punch and big hammer to push the sides of the tooth into the depression. I still lost one digging a stump out so I added a spot weld to each side. It should be easy enough to grind the weld off if I need to change one.
/ Backhoe tooth replacement #3
Heat would help to beat it in to hold. The other way uses roll pins to hold them on.
/ Backhoe tooth replacement #4
first I had to clean up with a grinder then I welded the new one on.
You can always pop the bucket off and stop by your local welder for $25.
/ Backhoe tooth replacement #5
I had problems with a loader that had teeth that had to be heated & dimpled into a hole in the shank. I couldn't seem to get it right. I cut 2 pieces of rod the same diameter as the hole in the shank into a length that was snug to slide the tooth over & plug welded in the hole in the tooth. Never lost a tooth that was done that way. MikeD74T
/ Backhoe tooth replacement #6
Teeth removal is a tricky and this is why it is important to get the expert services only. When I had to get the teeth removed, I just panicked but my cousin told me about her dentist Redondo Beach who is extremely experienced. Trust me, the dentist was very good and I didn’t have any issues during the procedure.
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2018 Club Car Carryall 1700 4x4 Utility Cart (A61572)
2018 Club Car...
