Backhoe Thumb that moves via mechanical linkage to the bucket
   / Backhoe Thumb that moves via mechanical linkage to the bucket #1
67FASTBACK428
Kubota B7500
Just wonder if there is a thumb that moves by linkage to the bucket, so there is no added hydraulic cylinders or valves? I am working on trying to make one.
thanks for any help,
troy
   / Backhoe Thumb that moves via mechanical linkage to the bucket #2
troy
Welcome! The members on this forum are not shy about disagreeing when they think you are barking up the wrong tree, and therein lies a great advantage.
Google "Tractor By Net mechanical thumb" or just "mechanical thumb" to get ideas. The disadvantage of a linkage that moves when the bucket moves would be that it moves when the bucket moves. There will be times when you won't want that. A mechanical thumb "KISSes" that problem neatly without the complication of hydraulics. Some even prefer a mechanical thumb because it can be set and not overpowered by the bucket curl like a hydraulic thumb.
Thanks Captain,
I have been looking, and have had a fixed thumb on a homemade backhoe that I built. I liked it and it worked good. I have a homemade band sawmill and tinker with that and move some logs now and then.
I just got a Kubota b7500 with a loader & hoe on it, I really like it! I just wondered if anyone had seen anything like what I am building or was interested...
thanks for all the looks and responses
   / Backhoe Thumb that moves via mechanical linkage to the bucket #4
What do you envision the advantage of a a thumb that moves with/against the bucket via fixed linkage? Wouldn't it always contact the bucket at the same point, like a fixed thumb?
It may help to sketch what you're thinking to get some feedback.
   / Backhoe Thumb that moves via mechanical linkage to the bucket #5
I'm sure this is what the OP is talking about:
Or this style. There is a thread about this somewhere in this forum. Here: https://www.tractorbynet.com/forums/build-yourself/94333-another-backhoe-mechanical-thumb-fixed.html
mechanical articulating backhoe thumb - YouTube
   / Backhoe Thumb that moves via mechanical linkage to the bucket #6
Welcome to TBN.
ptsg gave you some great pic and video info.
If you decide to build one please post a thread about it.
I use and adjustable fixed thumb on my 555A. 95% of the time it's pinned fully open, out of the way. Sure comes in handy when handling logs/brush/rocks.
Thanks guys. Lots of good info there, I am almost done & will post pics soon. I know it will probably be in the way for digging but it shouldn't be too hard to remove. But it will be handy moving logs, rocks & other stuff. I guess I just like building instead of buying... It may not be a lot better than a fixed one, but it surly be cheaper than a hydraulic one.
thanks again guys
   / Backhoe Thumb that moves via mechanical linkage to the bucket #8
There is a commercial version made by Amulet. Pretty expensive as I recall.
   / Backhoe Thumb that moves via mechanical linkage to the bucket #9
I totally understand!!! I was set on building my adjustable fixed thumb. So I Googled to find pictures. One company even posted a blueprint with all dimensions and material sizes!!!! I was excited!!!! Then I saw the price...…. I couldn't buy the material for what I could buy it for, delivered to my shop.... I swallowed my pride and bought. Can't remember for sure but it was somewhere around $225.
In your case there is more complexity. I'm guessing to buy one would be expensive.
I'm anxious to see your build. Please post pics when you get started!!!
   / Backhoe Thumb that moves via mechanical linkage to the bucket #10
I have the Titan 36" weld on thumb on my backhoe. At first I would keep it in the stowed position while I was digging then extend it to pick stuff up. It still had limited usefulness for clamping stuff against it to pick it up in the stowed position. Over time I have learned to dig with it in the 90* extended position. Haven't pulled the pin and stowed it in months.
2024 JOHN DEERE 3039R LOT NUMBER 165 (A53084)
2024 JOHN DEERE...
100 GAL FUEL TANK W/PUMP AND TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
