Backhoe Backhoe subframe
   / Backhoe subframe #11
Dozernut, RickJay and Hoeman... thanks for all the comments! Dealer has already noted the need for the reinforced toplink bracket on the 3 pt model.
The small Kub hoe digs to 7 1/2 ft vs. 9 ft for the big one. I understand the big deal to that is the longer reach means you don't have to move the rig as often, but it's just my own personal use, so a bit more seat time is a good thing.
Based on your comments, I am going to do some more checking about ease of attaching/detaching these two units before making any decisions. There are so many chores that changing implements happens a lot around my place... the one that's the least hassle to change may get the nod.
Of course a dedicated L48 would take care of that problem! /forums/images/graemlins/grin.gif I expect to hit my Super Lotto jackpot just about any day now. /forums/images/graemlins/tongue.gif Thanks again!
   / Backhoe subframe #12
grandad,
It's true that the bigger hoe would require less repositioning for trenching. However, the extra length has other advantages as well.
I've used my hoe a couple of times to transplant some shrubs. The larger hoe minimized "squashing" the shrub as much because the boom and dipper-stick are longer and don't squeeze the shrub as much. I've done it with the 7 1/2' hoe, but a larger one would have been even gentler on the shrub.
Also, there are times when you are limited to the set-up position of the tractor. Having the extra reach of the backhoe comes in handy when you just can't get the tractor closer.
Of course, one of the down sides of the larger hoe is that it has a higher transport height, which might be a concern if traveling through garage or barn doors. And, of course, they cost a little bit more.
Anything you get is better than a shovel, but if at all possible, I'd try to swing the largest one that can be safely put on the tractor.
Have fun trying to decide. /forums/images/graemlins/smirk.gif
~Rick
   / Backhoe subframe #13
Rick: ......<font color="blue">"I agree about the heavy duty top-link bracket. I put one on my B2910." </font>
Your comment about the bracket has me wondering if my dealer replaced the toplink bracket when my BH was setup initially. Did you request it at the time of purchase or is this something you persued after the fact? What does it look like? /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif Regards ..Raybee
   / Backhoe subframe #15
Rick: ...Thanks for the heads up. That link confirmed that I don't have
the HD bracket that's required, I'm ordering one now. ... Many Thanks!
/forums/images/graemlins/tongue.gif /forums/images/graemlins/shocked.gif ..RayBee
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2025 Electric Cart (A55853)
2025 Electric Cart...
