Backhoe Backhoe subframe and backhoe not attached together?
   / Backhoe subframe and backhoe not attached together?
Ok, thanks, but that is when it is used with the 3 point mount. What about with a subframe then? Thanks.
   / Backhoe subframe and backhoe not attached together? #13
With the tube under the sub can you scoot the BH forward enough so that it will sit down in front of the welded on bar stock? Do the ears then stick down far enough that you can pin under the sub? It would then be locked down. Just an idea.:confused: It is really hard to tell from the pics. but it looks to me like that would work.
Mike
The BH sits on TOP of the welded bars now. I put some pics up of the new mounting with the BH attaced to the subframe. The ears are in the middle of the frame now and I drilled a hole in each bar and put two big bolts through the hole to attach the 2 pcs together. Looks ok, but some how still does not look like it really should be. Need to do some more research. Thanks.
24in pin on excavator tooth bucket (A56436)
24in pin on...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2017 FORD TRANSIT 250 CARGO VAN (A59575)
2017 FORD TRANSIT...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
