Backhoe Backhoe sub frame and 3pt stabilizers
/ Backhoe sub frame and 3pt stabilizers #1
canadiantoy
Kioti CK35
Hi, I have a Kioti CK35 with a woods BH-80x attached with the woods sub frame.
When I installed the sub frame the woods instructions said to remove the 3pt stabilizers as they would interfere with the sub frame installation. The problem I have now is that I need to remove the backhoe and use my box blade. The stabilizers will not go on and I don't want to risk taking out a tire.
Does anyone Kioti or other have this issue with their backhoe sub frame and how did you resolve the issue?
Simon
/ Backhoe sub frame and 3pt stabilizers #2
I have a CK30 with Kioti backhoe. I do not have to remove anything to put the backhoe on my tractor.
Why won't the stabilizers go back on?
/ Backhoe sub frame and 3pt stabilizers #3
I have a DK40 with the Woods BH90. My instructions said not install the stabilizers for the initial install as they got in the way. But after the initial install I put on the stabilizers. I wouldn't use the BH with out the stabilizers installed, and use them. Why can't you get the stabilizers on? Is there something in the way?
The 4 point attachement bracket for the subframe don't allow the stabilizers to go back on. I will take some pictures tonight to demonstrate the issue.
Simon
/ Backhoe sub frame and 3pt stabilizers #5
DK50SE with Woods 90x and subframe, no issues with the stabilizers either
3pt 4 Row Bottom Plow (A64119)
3pt 4 Row Bottom...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61573)
2010 Workhorse...
UNUSED WOLVERINE SB78-78" ROCK BKT (A64281)
UNUSED WOLVERINE...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
2012 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2012 KOMATSU...
