Backhoe stack valve plumbing
   / Backhoe stack valve plumbing #1
Trucker1
Western Maine
John Deere 4510
Hi all,
I've been searching and I can't figure out the answer to my question.
How can you tell which way the flow goes on a backhoe stack valve?
There are no markings that I can find to show the in/out direction. This is an older Kelley backhoe with just a hydraulic line on each end of valve bank. There is a pressure guage and relief valve on one end. Is this the "in" end of the valve bank? I haven't been able to verify this for sure. Any help is appreciated, Thanks
   / Backhoe stack valve plumbing #2
That appears to be correct, a relief and gage would be on the input side. With it connected to the hydraulics, you should show low to some pressure, and if you activate a valve and hold it, the relief will activate and show the relief pressure on the gage. The system pressure should be higher than relief pressure.
Thanks JJ,
That was the line of thinking I was on. I hooked it up that way and pressure shows real low; then, when I operate a cylinder the pressure comes up a little til it gets to end of stroke and then jumps to 1800-2000 psi on relief. I just wanted to be sure I was going the right way with it.
   / Backhoe stack valve plumbing #4
Sounds like you have got a handle on it. You are one of a few that have a gage in any hydraulic circuit, and it would solve many questions that are asked on this forum.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
2014 MACK PINNACLE (A52472)
2014 MACK PINNACLE...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53472)
GOODYEAR SET OF...
2022 John Deere RD35F Draper Head (A53342)
2022 John Deere...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
